Found hole in bed..rust
Old 10-30-2005, 03:10 PM
pat2724's Avatar
I have 95 Tacoma and it had a bedliner in it and today I decided to remove it and I found a rust hole about the size of a golf ball.
I had wire wheeled it and sprayed it with rust seize and painted it.
How should I fix it? I was thinking riviting a peice of metal and sealing it with silicone.
Any ideas??
Thank you.
Old 10-30-2005, 06:23 PM
Glenn's Avatar
Where is the hole?
Old 10-30-2005, 08:08 PM
pat2724's Avatar
the hole is located just above the gas tank upper passenger side where the seam is.
Old 11-01-2005, 08:50 AM
Lt. Dan's Avatar
I'm surprised that is the only place with rust! I had a 89 dodge PU that had a bedliner factory installed that was rusted everywhere.
What do you want to spend, what are you willing to live with?
Riveting will work for a while, but the silicone will eventually fall out. To fix it properly yer gonna need to get a piece of metal welded in by a decent welder.
You are on the right track wuth the wire wheele and rust stop paint. But the paint will have to come off if your gonna weld it.
Do whatever you can afford, you gotta live with it.
TDonkey
07-26-2015 10:14 AM
whereAreMyPants
07-22-2015 03:32 AM
voiddweller
07-15-2015 03:56 PM
smiley52
07-11-2015 05:16 AM
Avenged
07-09-2015 07:55 AM
Quick Reply: Found hole in bed..rust
