fog lights
If you have a SR-5 or Limited 99-02, a replacement to the factory fog lights is the Hella's.
It has a different bracket but is specific to the 4Runner.
Take a look at Hella Micro DE's for the 4Runner
I know several members who either replaced theirs or installed them on their SR-5. You can either plug into the factory harness and use existing stalk switch or if an SR -5 use their dash switch. Good instructions.
if you do go with those hellas, I had problems with water getting in so once i got them in good working order, I put a little silicone around the rubber seal on the back end and that seems to have solved the problem. Granted, the truck as been swimming a few times haham, still, not a bad idea if you ask me
https://www.yotatech.com/forums/f2/4...-style-164664/
If not, there's a link in there where someone has fabricated some more professional-looking splash guards.
Otherwise, there's this one: https://www.yotatech.com/forums/f2/3...shields-58066/
are the hellas better than the factory ones? I found this set that is identical brackets and everything,http://cgi.ebay.com/ebaymotors/99-02...6028QQtcZphoto don't know about the quality, with the hellas I would need new brackets right or can the old ones be used?
ashersullivan88yota
01-18-2022 05:37 PM
FS[PacNorWest]: Toyota Inclinometer/Altimeter
AkitaDog
09-01-2015 08:05 AM
PopsDad1
07-30-2015 02:21 PM
Odin
07-15-2015 09:28 PM
