Fog light mod revisited on 2000 4runner
I did a search but did not see this detail: can you still do the mod (to turn your fog lamps on w/o the headlights) if you disabled your drl's?
I did not like the drl's so i disabled them according to the advice here, just unplugged the box under the hood near the fender.
Now, I'd like to be able to turn on my fogs w/o the headlights. Is this still possible?
Have you done any reading?
https://www.yotatech.com/forums/f2/c...read-me-97208/
Post #8
then
http://www.top4runners.com/ja/fogmod.html
So therefore, you should be fine
Post #8
then
Granted, the drl system on my '02 differs from yours, but I've disabled my drls and have done the fog light mod too. Works great. Here's the fog light mod I chose: click me
However, for your situation, you could try this type fog light mod and see how it works. It's quick and easy. If it doesn't work, the wiring can easily be removed: Click Me too
Good luck!
EDIT: Godzilla, you beat me to it I see
Good luck!
Does anyone know if this link/directions https://www.yotatech.com/forums/f127...ght-mod-87997/ works for a 99? Is the relay box, relays and wiring all the same?
I would prefer to do the more permanent mod if possible, but I've got a 99 and don't want to be cutting the wrong wires.
Thanks!
Thanks!
06-01-2021 01:51 PM
icentropy
07-11-2015 07:21 AM
Avenged
07-09-2015 07:55 AM
Jnkml
07-06-2015 01:20 PM
