| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
__________________
99 4runner: 6 inch deck plate mod, Differential Breather Mod, XM Radio and GPS. |
#2 (permalink) |
Every time you replace your clutch you need to machine the flywheel due to glazing and heat spots. If you don't you end up with a slick surface and that cuases your new clutch to chatter (it doesn't grab nicely). Also when replacing the clutch you need to replace the pressure plate to ensure that there is sufficient spring to allow the clutch to grab. Was all this done???
Putting in a heavier flywheel will kill some of your power and fuel economy. Some people with bigger tires are putting in lighter flywheels to regain some of the lost power from the extra weight of the large tires.
__________________
Matt 2003 4-Runner Limited - Couldn't stay away from the runner 2003 Sequoia Limited 1989 Supra Turbo 1992 4r, 5spd V6 Sold |
#3 (permalink) |
I know they did not macine the flywheel. They told me that yesterday. I think the preasure plate was done but not 100% positive, maybe 90% sure.
I thought putting a heavier one would give you better bottom end and hi-way mileage. I quess a lgihter one is the answer? Thanks for the quick reply.
__________________
#4 (permalink) |
I just replaced my clutch, and got my flywheel machined. My starts are REALLY smooth, and shifting is perfect, the clutch grabs really well too. I used an OEM clutch, i was going to use a centerforce dual friction, but it was WAY expensive (over $400)... i found an OEM clutch for $250. From what i've read the centerforce dual friction is nice for not slipping, but that can be a bad thing, when you clutch doesn't slip, that torque and power has to go somewhere... ending up with stuff behind the tranny being broken.
I've also heard the ACT 6 Puck can hold it's own. Although, I really recommend the OEM clutch... it lasts a long time, and mine grabs REALLY well; apart from doing heavy offroading or racing it's totally sufficent and it will save you some cash too. The guy i know with the ACT 6 puck is supercharged though... so it might be overkill for your application. As for a heavy flywheel, like the other guys said, kills gas mileage and acceloration... but you can get more torque. |
#5 (permalink) |
I am wondering how big of a job it would be to do the work myself. Has anyone done the work themselves? I consider myself pretty handy, just finished putting a BMW r100 back together.
__________________
#6 (permalink) |
the hardest part is getting the bolts for the bellhousing out (the top ones are close to the fire wall) You will need to support the gearbox well so it doesn't drop but the job isn't too bad.
__________________
#7 (permalink) | |
Quote:
Me and my buddy did it ourselves. He was the handy one, i was the one helping. Anwyays... if you do do it yourself, make sure you have a transmission jack, makes the job a LOT easier. If you have a hydrolic lift or a pit, i'm sure that WOULD have made it easier (mine was on jackstands)... Make sure you have loctite for putting the flywheel back on (blue works fine), RTV sealant, if you take the transfer case off, and some high temp grease to lube the throwout bearing. Also, is your 4runner 2WD or 4WD... because the 4WD tranny has the transfer case on the back end, which makes it slightly more difficult. To give you an idea of what has to be done... you have to remove the driveshaft(s), take out the shift levers. and take off the wiring harnesses from the transmission (the part that sounds easy, but actually ends up being one of the hardest jobs). Also when putting it back together, MAKE SURE YOU DONT MIX UP THE 4HI AND 4LO harness... they are the same, and are interchangeable... that made for some pain in the ass troubleshooting after finishing the clutch. Last getting to some of the transmission to engine bolts is a pain, but it's do-able. Get a clutch kit and replace the throwout bearing, clutch plate, pressure plate, and pilot bearing. DEFINITLY resurface your flywheel, i bought my clutch from carquest, and because of that the local guys did my flywheel for free (nice guys). All in all, it took us two nights, first taking it apart, and taking the flywheel off... after it was resurfaced, putting it back together the next night. Took us about 8 to 10 hours total. I have to say i don't know how experienced you are, but there was a few times i was frusturated and felt like i was in over my head.... but it was all worth it in the end, and everything works GREAT (good to know how it's done, and the satisfaction of knowing it's done right) here is a site which tells you what it takes to do it, and some instructions.... if you have a repair manual, that's helpful also... plus you can get torque specifications (although, just post here and i'm sure everyone woudl be happy to tell you what torque specifications you need) http://www.4x4wire.com/toyota/4Runne...enance/clutch/ |
#8 (permalink) |
I had my flywheel resurfaced and I went with a Marlin Clutch kit. I'm very happy so far.
A heavier flywheel will help with low end torque for towing and offroading, but it will hurt everywhere else. Nobody makes a heavier flywheel for the 3.4 anyway-I looked very hard for one when I replaced my clutch.
__________________
1985 4Runner Dual e-lockers, dual cases, yada yada 1996 4runner, lifted, 2 lockers, 315 KM2's, IFS and more '00 Suburban 2500 4x4 '07 Tacoma Double Cab 4wd TRD '02 Lexus IS300 1991 Tiffin Allegro 31' Class A |
| Tags |
| flywheel, is300, resurfaced |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 22RTE clutch/flywheel in 22RE setup???? | Yoda | General Vehicle Related Topics (Non Year Related) | 8 | 04-12-2009 07:28 PM |
| Installed a new flywheel and clutch | AH64ID | 86-95 Trucks & 4Runners | 3 | 07-30-2006 05:18 AM |
| clutch/flywheel replacement question | hektikwon | 95.5-2004 Tacomas & 96-2002 4Runners | 2 | 11-10-2005 02:31 PM |
| flywheel torque, and clutch face direction on 3.slow | Eric | Maintenance & Repair Archives | 3 | 04-08-2005 08:18 PM |
| How important to get flywheel resurfaced when changine clutch?? | wimpywade94 | Maintenance & Repair Archives | 7 | 06-28-2004 09:41 PM |
