| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Flat spot?
__________________
"Live and learn, Die and forget it all" 1996 4Runner SR5 V6 4x4 Lifted, Locked, and Armored
#2 (permalink) |
if it isnt going anywhere its not the tires... might be the brake caliper or drum hanging up....
#3 (permalink) |
I am more than fimaliar with the calipers and rotors vibrating. I had two warped rotors, and my calipers were both shot. But, I replaced my rotors, calipers, and brake pads right after Christmas. Put my bilsteins on right after that and got it aligned because I screwed up my balljoint and steering arm in the process. Also I replaced my drums, shoes, and the cylinder inside the drums not to long ago. The mud down here really eats that stuff up. I rechecked all of that when this problem arose. Checked to make sure nothing was loose too. It all seems fine to me, but maybe I will double check it.
__________________
#4 (permalink) |
well after working in the tire industry for like 5 years, i can sya that if its still there regardless of the tire position, its not tire related or all 4 of your tries are screwed up and you only think its coming form the rear....
#5 (permalink) |
Hmmmm looks like I am gonna have to put it in the air and check back over anything. Thanks man
__________________
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| not sure if this is the right spot... | maxxjq | Off Topic Talk | 2 | 03-05-2006 02:37 AM |
| OEM Temperature Gauge - Flat Spot | Philly72 | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 11-08-2005 10:45 AM |
| **HELP** Flat tire---can't get the flat off | bradym239 | 95.5-2004 Tacomas & 96-2002 4Runners | 27 | 01-26-2005 10:28 AM |
| spot the difference | lee | 95.5-2004 Tacomas & 96-2002 4Runners | 6 | 12-10-2004 11:39 AM |
| Flat spot at 3000 rpm | robbieracer | 95.5-2004 Tacomas & 96-2002 4Runners | 8 | 10-23-2003 09:34 AM |
