Fitting 35's on a 3rd gen without going sky-high. - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 12-02-2005, 01:43 PM   #1 (permalink)
SEAN_at_TLT's Avatar
I recently ordered a set of Maxxis Bighorn tires in 305/70/17. That metric size equates to 34x12.2", or roughly the same size as BFG 35x12.5" in reality (EDIT: After measuring the Maxxis against the BFG's, they are EXACTLY the same size). The tires won't be here for a few weeks since they are on back-order but in the mean time I needed to make room the new meats. My rig is already geared for 35's so that's not an issue but the 285's I've been running for a few years now barely fit at full compression as is.
We have a set of BFG muds in 35x12.5 on hand since that's what we run on the red Tacoma so we had tires to use for mock-up purposes. We decided to go ahead and clearance the inner and outer fenders for when the new tires arrive. Having done similar work to the Tacoma we knew this project would take us at least a full day for the front alone and we estimated about the same for the rear but having never done the rear of a stock bodied 4Runner before we couldn't be sure we wouldn't run into a snag along the way.
We did the work over Thanksgiving weekend and it came out great. There is still a little bit of finishing work to do on the rear but I'll have to wait for the rain to let up to get to that. The end result looks factory clean and will let me run a full 35x12.5" at full compression and the only even slight rubbing is on the frame-rails at full-lock steering (regardless of suspension position) and also slightly on the firewall at full-lock steer AND full compression which is a situation that will rarely if ever occur.
Here's a link to the pics and a brief write-up. There are no final pics yet because like I said the tires are back-ordered and I still need to paint the rear fender lip but you can see the basics of the project in good detail. This is a time consuming but relatively simple modification that is of tremendous benefit.
Tools needed:
4" angle grinder
Welder (TIG or MIG)
Various common hand tools
Supplies needed:
6-8) 4" Cut-off wheels
1) 4" Flap Disc
1) 1-1/2 x 2' piece of sheetmetal, ~3/32" or thicker depending on preference.
1) 10' length of 3/16" steel rod
1) Can rubberized undercarriage coating spray (Bondo and Dupli Color brands are good)
1) Can primer
1) Can semi-gloss black spray paint
1) Roll masking tape
1) 10' roll universal door edge trim
1) Tube clear silicone sealant
1) 14oz. can of body filler
1) Package sand paper, various grit levels
__________________
-Sean
Trails Less Traveled
SEAN_at_TLT is offline
Old 12-02-2005, 02:45 PM   #2 (permalink)
Cebby's Avatar
Send a message via AIM to Cebby
Sean - perfect timing. I'm going to need to do something similar very soon. Nice writeup!
__________________
UZswap.com
A site dedicated to sharing info for swapping the Toyota/
Lexus UZ (V8) engines into Toyota Trucks and 4Runners.
My 4Runner
1993 4Runner, 1UZ (V8) auto dual ultimate crawler, double locked, 35's on beadlocked SR5 alloys,
low lift, hacked fenders, tubbed firewall, custom armor
TOOLandFAB.com
A discussion forum dedicated to tools, fabrication & workshops. See my JD2 Bender Hydro Conversion
Cebby is offline
Old 12-02-2005, 02:54 PM   #3 (permalink)
colsoncj's Avatar
Send a message via AIM to colsoncj
Great writeup and pictures! 5 stars!
__________________
Cory
Eastern OK, Western/Northern AR, Southeastern KS, or Southern MO area: OZARKS 4ROC Click Here
04 Dodge 2500 Cummins - DD/Tow Rig
02 Z06 Corvette - Weekender
94 FZJ80 - Wheelin Rig. Build in progress: http://ttora.com/forum/showthread.php?t=129727
72 Buick GS - i.e. the project that will never get done.
colsoncj is offline
Old 12-02-2005, 03:31 PM   #4 (permalink)
thanks for the positive feedback guys, the rain actually broke and I am working on finishing up as we speak. Look for final pics soon.
BTW, I also updated some of the captions with more detailed info.
__________________
-Sean
Old 12-02-2005, 05:32 PM   #5 (permalink)
calrockx's Avatar
Send a message via AIM to calrockx
Quote:
what he said.
__________________
[2002 4Runner 4WD]
calrockx is offline
Old 12-02-2005, 05:45 PM   #6 (permalink)
It's nice now that our 3rd gen trucks are getting a little older we don't have to cringe so hard when cutting into the sheetmetal. That made the job a bit easier
__________________
-Sean
Old 12-02-2005, 05:50 PM   #7 (permalink)
Super Moderator-Sponsoring Member
Staff
waskillywabbit's Avatar
Send a message via AIM to waskillywabbit Send a message via MSN to waskillywabbit Send a message via Yahoo to waskillywabbit
My sheetmetal looks better since I cut into it.
Nice job!
__________________
WabFab Off-Road, LLC
MySpace
Twitter
Facebook
7th Annual South East 4Runner Jamboree, 2010
The toughest part of a Jeep is the chick driving it.
waskillywabbit is offline
Old 12-02-2005, 05:59 PM   #8 (permalink)
Quote:
Nice job!
That's usually the case but sometimes it's hard to convince yourself of that beforehand.
When the angle grinder or sawzall comes out you're like :cry: but then after it's more like
__________________
-Sean
Old 12-03-2005, 01:38 PM   #9 (permalink)
SC4Runner's Avatar
Are you back up in Santa Cruz?!
That looks great. I wish I would have the patience to cut my fenders ... and lower my truck
Can't wait to hear about the final result!
__________________
1996 4x4 3.4L 4Runner on 35's - 6" of lift, MTR's, E-locked, ARB Tacoma Bumper, Sliders and a cut off tail pipe.
1966 FJ40 - SOA with stock springs, stock 1F motor, and a smelly tailpipe.
SC4Runner is offline
Old 12-03-2005, 03:23 PM   #10 (permalink)
I am still in SB but I was up there for the holiday.
__________________
-Sean
Old 12-03-2005, 03:31 PM   #11 (permalink)
msw0085's Avatar
Send a message via AIM to msw0085
haha your truck is SO TALL..
__________________
TOYOTA|moving forward
1996 3.4 Litre | 4-Wheel Drive | 5-speed Manual Transmission | Magnaflow Exhaust
Deckplate | Intake Silencer Removal
*MasterDebater*
msw0085 is offline
Old 12-07-2005, 05:42 AM   #12 (permalink)
northfacer581's Avatar
Send a message via AIM to northfacer581
im running 305/70/16's, and i thought they were equivalent to 33's?
__________________
-Andy
99 4runner 5speed
Lift: 3" revtek & 2" body; swaybar discos; diff drop
Performance: TRD s/c & 7th injector kit, deckplate closed, elbow removed, TMC 1.1, lock-rite in rear
Protection: tjm15 w/ tabor 9k, custom sliders
Shoes: 305/70/16 nitto terra graps on 16x8 helo maxx 6's
Stuff: lots of lights on the surco, yakima big powderhound right now, shackle hangers, sony head unit, aux fuse box, full time power outlets, seat covers, and home of the herculiner mod
northfacer581 is offline
Old 12-07-2005, 09:20 AM   #13 (permalink)
Quote:
I am running 17" rims and with metric sizing that's where things can get confusing. With an American sized tire the first two numbers describe the outside dimensions of the tire (diameter/width) while the third number describes the rim diameter. There is no measurement for the height of the sidewall however.
With a metric tire the first number describes the width of the tire and the second number describes what percentage the sidewall height is relative to the tire width (in this case 305/70 = 70% of 305mm) . So by changing the rim diameter (and not changing the numbered size of the tire) you are changing the overall tire diameter. If a 305/70/16 equals a true 33" diameter tire than a 305/70/17 will equal a true 34" tire and a 305/70/18 will equal a true 35" diameter tire. BFG American "35-inch" tires measure out to a hair over 34" FWIW.
EDIT: I am finishing up the job right now and should have some pictures up later today. Also I decided on rims and I'm going with a set of 5 American Racing (forged) Sidewinders with OMF beadlocks. The tires just showed up in the mail but the rims will take a while to get beadlocked. I'll post pics when it's all done.
__________________
-Sean
Old 12-07-2005, 09:20 AM   #14 (permalink)
SC4Runner's Avatar
Quote:
It's all relative dude...
I look at my truck and it looks like its sitting at stock height. I drive around town and stock F-350's and such are sitting level with me!
__________________
Old 12-07-2005, 11:43 AM   #15 (permalink)
yea dude i noticed that too...it seems like everyday that goes by, the 4runner gets smaller and smaller....
__________________
-Andy
99 4runner 5speed
Old 01-29-2006, 07:35 PM   #16 (permalink)
Okay well I finally got the wheels and tires in and got a chance to mount them up and go wheeling.
First off bead locks are great because you can mount your own tires at home with only a torque wrench. It took me about 2 hours to get all 5 tires mounted. I took them to get balanced but in the end they were so well balanced that that was a waste of money, barely any weights were used.
We took the truck out for some wheeling outside of Bend Oregon, we found this area with a huge rut running down the crack between two hills. After a slippery sidehill I had to drop into the lower part of the ditch diagonally and then climb up the steep hill to the top where I had to jockey the truck around to get a good line to cross back over the ditch to the top of the hill.
This was the hardest part as the front driver side wheel had to go straight up a 3' high vertical wall. The truck handled it great. I bashed both bumpers into the rocks but both were unscathed.
The ARB did it's job as did the new meats, they grip like mad and thus far haven't chunked at all. As an added bonus they look great with an aggressive tread pattern and side lugs.
After that we ventured deeper into the forest for some snow wheeling. There was about a foot of fresh on top of some hard pack which was perfect for roosting around.
__________________
-Sean
Old 01-29-2006, 07:41 PM   #17 (permalink)
SnoViking's Avatar
Send a message via AIM to SnoViking
are true beadlocks legal in CA? cause here in PA theyre not legal for street use.. just wondering
__________________
Pat
1999 4Runner SR5 V6 4WD - Brush Guard, lift, Duelers, roof rack, acouple lights
~You will always be my little boy~
Hobbes
(11/28/05)
Future mods- more lift, tire gate, sliders, better lights, engine upgrades.
SnoViking is offline
Old 01-29-2006, 07:41 PM   #18 (permalink)
FilthyRich's Avatar
X1000000000000
__________________
Eric
88 4runner
Quote:
Originally Posted by AxleIke
"Just wheel what you got until it doesn't cut it anymore".
FilthyRich is offline
Old 01-29-2006, 07:44 PM   #19 (permalink)
They are not DOT legal I believe however these here rims are just "street locks" officer.
__________________
-Sean
Old 01-29-2006, 07:47 PM   #20 (permalink)
SnoViking's Avatar
ahh... i love that look
__________________
Pat
Hobbes
(11/28/05)
Old 01-29-2006, 07:51 PM   #21 (permalink)
Flygtenstein's Avatar
Looks good.
Beadlocks are not illegal anywhere. They are not legal anywhere either.
I have some really sweet streetlocks from OMF as well.
If you are thinking of buying fake ones, please do. That way those of us with real ones can get off the hook.
__________________
Ease on down the road.
Flygtenstein is offline
Old 01-29-2006, 08:02 PM   #22 (permalink)
Quote:
Originally Posted by Flygtenstein
Looks good.
That's kinda what I thought. I seem to remember that those big rig style 2-piece rims are illegal and people were confusing that with beadlocks or something. Anyway I'm not worried about it as we've run beadlocks for years, first some Barts on the jeep and then OMF's on the Tacoma and now these and we've never been hassled once.
__________________
-Sean
Old 01-29-2006, 08:03 PM   #23 (permalink)
wow those pictures are awesome.
i got streetlocks! ill be sure to let the officers know!
__________________
-Andy
99 4runner 5speed
Old 01-29-2006, 08:11 PM   #24 (permalink)
SnoViking's Avatar
i want them!
__________________
Pat
Hobbes
(11/28/05)
Old 01-29-2006, 08:12 PM   #25 (permalink)
Really, truck looks good.
Schaefer's rig worked tits that low with IFS too.
Perhaps beadlock discussion deserves another thread, but I got rear-ended out here and the cop made an effort to say nice wheels when he was looking over my truck.
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
How to fit 35's on a stock 3rd Gen... Toyofast 86-95 Trucks & 4Runners 49 01-17-2009 06:15 AM
fitting 3rd gen seats in 2nd gen Wayne 206 86-95 Trucks & 4Runners 1 05-03-2006 12:00 AM
3rd gen tire fitting hiloracerboy84 95.5-2004 Tacomas & 96-2002 4Runners 3 09-11-2005 12:29 PM
Fitting a 285 in the spare tire area on a 3rd gen? amorphous 95.5-2004 Tacomas & 96-2002 4Runners 8 04-22-2005 08:03 AM
Fitting 285's on 3rd gen ARB4STUNNA 95.5-2004 Tacomas & 96-2002 4Runners 9 11-28-2004 12:22 PM
2009 InternetBrands, Inc.
