Fitting 285's on 3rd gen
I have 97' SR5 4x4 and recently installed OME 881 coils with 2 trim packers on each side up front, and OME 890 coils out back...with OME firm shocks. I currently run 265/75/16 on stock wheels and it looks like there is alot of space for bigger tires. From anyones experience with this set up will 285/75/16 fit with out much rubbing under full stuff?? Or should I wait and get a 1" or 2" BL??
Thanks for any info.
You should search and read what every other person has to say on this board.
Be careful though, every 4Runner is different. Some will rub, some wont, there are too many variables.
On paper, yes there is room, especially after you trim the necessary pieces, but something strange might through you off.
Personally, I think bodylifts are dangerous. If you hit something just right, you can shist the weight of the body forward on the mounts. And, they involve more labor than installing new coils on the front. I can break down the front suspension in less than an hour. The fastest I've heard someone installing a BL is 4 hours.
Back to the question..It would be easiest for you if you were to add a 1"BL to the equation. Also the 891's only yield about 1.5" of lift alone.
Thanks for the info. I may just get the 285's and if they rub too much, go ahead and add the 1" BL. Does anyone know where I can get a good deal on a 1" BL or wich is best and easiest to insatll?? Thanks again!!
Welcome noob.
BTW guys, what is the biggest size tire I can fit on a stock 3rd gen?
What is the deck plate mod? Who builds a custom rear bumper? How much oil does my engine hold? Where do I crank it? With a key?
I plan to add a top out spacer up front as it sits 1/2" lower than the rear. This should help my problem.
Brian
4 hours is a typical body lift kit install, but it can be done in less time, depends on the complexity. Also, no special tools are needed. I once helped install a 3rd gen OME lift kit and two of us spent all day on it and finally had to give up on the front end after my spring compressor would not quite get the new springs compressed enough to install them. Owner took the rig to a shop and they finished the front end in an hour or so with the right kind of compressor.
33"s: Without a BL, plan on lots of fender pounding if you wheel your rig heavily. Otherwise a spring/spcer lift will do for the street. They'll still rub on the frame at full lock. Might depend on the tires though. Some 33"s run smaller than 33". 285/75/16 Revo's measure 33".
06-01-2021 01:51 PM
jerusry
10-19-2015 05:28 PM
ChiefTetlow
08-10-2015 04:19 AM
