First parts to break in IFS ?
Old 11-07-2005, 03:10 AM
ThomasJ's Avatar
I did a search and did not really find an answer. What are the first parts to break from off road abuse on the IFS with ADD? CV's, hubs, differential, inner axles, etc. ?
Old 11-07-2005, 03:31 AM
Schooler's Avatar
I would say the CV joints
Old 11-07-2005, 03:58 AM
seaflea's Avatar
the Cvs may be the first to break, but the Idler arm is the first to bend and hit the frame. Seems to be the weakest point on IFS.
Old 11-07-2005, 05:05 AM
midiwall's Avatar
CV's... It's the only thing I've actually broken, and I off-road with my right foot.
Old 11-07-2005, 06:16 AM
Guest
oly884's Avatar
Well it's either going to be the CV boot or the CV joint. I never broke a CV joint, but I did break a couple boots in my time.
Old 11-07-2005, 06:40 AM
Intrepid's Avatar
As stated above, CV's are the worst. Tie rod ends will go and eventually you could have some steering rack issues. It all depends on tire size and how much abuse you give it.
Old 11-07-2005, 07:51 AM
Fink's Avatar
Depending on tire size and abuse...the idler arm is WEAK, been there done that! I'd get the idler arm brace from Downey.
Fink
Old 11-07-2005, 08:06 AM
Churnd's Avatar
Fink
While it rarely ever actually breaks, it can get bent and become very annoying if your rig is a daily driver. Especially if you have bigger tires. Take it from me and save yourself a lot of headaches in trying to figure out why your truck's front end won't align properly and get that idler arm brace.
Old 11-07-2005, 08:12 AM
deathrunner's Avatar
or the total chaos idler, but it's bit more $$
icentropy
09-16-2020 02:47 PM
XtraCab
04-12-2020 05:25 AM
thefishguy77
07-30-2015 10:59 AM
akaphilly
07-09-2015 02:34 PM
skoti89
07-06-2015 07:45 PM
Quick Reply: First parts to break in IFS ?
