View Poll Results: FIPK or cut out my airbox?
K&N FIPK
73
29.20%
Cut out the airbox
177
70.80%
Voters: 250. You may not vote on this poll
I'm trying to decide if I want to order a K&N FIPK or to cut out part of my airbox. If I do the latter, I will just order a K&N replacement filter and do the ISR (which I've already began gathering supplies for).
What do you guys suggest?
Originally posted by ALBPM
Deckplate and Amsoil air filter
3.0= no deckplate or amsoil
and that makes me mad because i want to do it so badly
Originally posted by doink
again, agrunner has the 3.0
I'm unfamiliar with the difference in the 2nd gen setup concerning the airbox. Is the airbox just shaped differently and makes the deckplate impossible or is there some performance based issue? Different shape air filter too? Just curious why the deckplate can't be done?
Thanks!
Brian
air box is completely different, round, no room for large holes to be cut. is that right? I was looking over a buddy's '92 and didn't see much that could be done. I would say just buy a K&N filter only (not the FIPK) and that is as much flow as you're gonna need. People will say it will be dusty, but it would be the same as a FIPK. Maybe less, and at least you'll still have the factory snorkel for piece of mind. Or just stick with the stock filters because they will do the best job of filtering. I think that no matter which way you go with intake, the only noticeable difference in performance will be the sound. unless you're supercharging or turbocharging.....
I think this is what he's talking about when he's talking about cutting up his airbox.
Originally posted by waskillywabbit
Doink,
Thanks!
Brian
Doink,
Thanks!
Brian
The 3rd gen airboxes have a nice flat side in the front of the box for cutting a hole and mounting the deckplate. The 2nd gen boxes have no flat sides and are pretty much round throughout. Even the bottom itself is curved. So no deckplate for us.
Originally posted by Churnd
I'm not Doink, but I know the answer.
FIPK for the 2nd gens with the 3.0L, works very well.
(can do it cheaper, just cut out bottom of airbox)
Deckplate and Amsoil for the 3rd gens with a 3.4L
Can someone please explain, I'm trying to learn as much as possible.
Thanks
Juggalo
Here's a link to the deckplate mod (it's in the tech section of this webpage)
https://www.yotatech.com/~corey/tech.../deckplate.htm
As far as Amsoil - it's a foam filter that uses an oil to catch the little things that like to fly around in the air.
Here's a link to the washing instructions (also found in the tech section)
http://www.hboss.net/4runner/amsoil-filter-cleaning.htm
If you're looking at more mods I'd suggest checking out the TECH section here as it's REALLY cool
Bob (Bob_98SR5) has a good website where all his write-ups are too. They're all very detailed and thorough.
http://www.4runners.org
He's also an Amsoil dealer so if you're looking at buying an Amsoil filter you can look him up.
truckmike,
Do you think you could give me the part number for the K&N cone? I thought about going that route but wasn't too sure because they've got quite a few with different dimensions.
Thanks
EDIT: If anyone else has a K&N cone filter on thier 2nd gen, could you please give me the part number?
Thanks
Originally posted by AgRunner06
truckmike,
Thanks
truckmike,
Thanks
Originally posted by truckmike26
It's RE0930 -- six inches long (tapered cone) with a three-inch inlet -- I feel it's the largest size cone one can practically fit without too much work. I could have gone larger, but I would have had to drill extra holes and made more complicated brackets to support the air flow meter.
Did you have to make a bracket to support the AFM? I'm sure I can do this because I have access to a shear, cut-off saw, and drill press. How complicated was the bracket?
Where did you get the adapter for the cone filter? I saw one at Autozone. It said that it would fit the older Supra AFM or MAF (not sure which). So I'm guessing that it might fit my AFM too. I'll just have to measure it before I buy it.
Thanks Again
The bracket is nothing more than a piece 1/8 by 1-inch aluminium bent into an "L" with some holes drilled into it. When you remove the factory pipes (it's amazing at how much space there is in there with all that junk outta there! ), the air injection "muffler" that has to come off the main air box because you'll still need it. I stuck a K&N 3/4-inch crankcase breather in place of that curved connecting hose (the one that goes from the "muffler" to the main air box lid).
The adaptor is from Vibrant (PN 1996). The 45 degree, 2-3/4-inch polished bend is also from Vibrant (PN 2880) as is the blue silicone coupler (PN 2184). The airflow meter comes off the air box lid and I attatched the L bracket to the existing holes that held it there. The L bracket bolts to the inner fender to one of the holes from the factory system.
You'll need to slice down the 45 bend lots and find a way so the 2-3/4 O.D matches the truck's factory bend from the throttle body as it's has a bit larger I.D. (wrapped a few rounds of duct tape -- shhh, don't tell! )
It's definately not a bolt-on as lots of trial fitting a cutting-to-size in necessary. But I had tons of fun doing it, it sounds wicked (especially at WOT) and gives some more power. Probalbly doesn't work as well as a true cold-air/shield system, but I like it. Plus, checking the air filter is easy! One other thing is you'll have to drill a hole and adapt a fitting somewhere for the A/C compensator hose (small dia., same location as where the air injection hose connects).
Oh, any import tuner store has this stuff and companies like Ractive and Matrix make the same parts (same parts, different brand name). Feel free to ask anything else.
