Final wire issues with FMU
Down to my last wire issues but much confusion still. I read and re-read the istructions from the 3 here who have this installed but I am still confused.
The issue for me seems to be the 10 pin/9 wire connector on the FMU. There is no corresponding connector on the US version. So now I have the following unknown hook ups remaining: One wire is for 12vdc constant, one for ignition, dash light dimmer, speedo sensor. The temp sensor I have figured out and have the wires run from the sensor to the overhead panel. I got from the text the 12vdc constant was from the clock 12vdc? Or was that supposed to be for the dimmer? If it was for the dimmer which of the four (4) wires on the clock plug needs to be spliced into to make it work? I found 12vdc constant with my meter as that is blue/yellow and is the top wire on the connector. Speed sensor wire routed but where does it connect? The instructions alluded to says ABS module, what the heck is the ABS module? I found what I believe to be the ECU module behind the dash/glove box on the passenger side, at least thats what the Toyota tech told me. Is this where it is supposed to go? And what wire does it need to be spliced into? I can not pull the unit out only can get to the wire bundles. Ignition is another that I have no idea where I need to hook this up. There is no connection for this unless you have to slpice into the smaller 6 wire connector that is for map light/sun roof control. I have that working just fine, but need to know about the other wires. I almost have this unit installed. I can use the ehlp here guys! Thanks
FS[SouthEast]: Mercury Villager Fan & DCC Fan Controller
coryc85
09-09-2015 06:24 AM
