| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#151 (permalink) | |||||
__________________
-Johnny --------------------------------- '96 Taco V6 4WD Auto with 262 S2S Cams New 5VZ-FE & 3VZ-E Cams available 5vz-fe Stock CR FI Pistons NOW available! www.sea2skytuning.com Plug and Play EMS! Perfect Power, Hydra EMS, Arias, Pauter, Manley Performance Dealer.... |
#152 (permalink) |
Node, did you disappear?
__________________
Tommy L. -1999 Black SR5 "HIGHLANDER"- ~295/75/16 NITTO TerraGrappler~ ~16x8 MICKEY Thompson Classic Lock~ THE PICS MY YOTA TECH PROFILE |
#153 (permalink) |
He will return
__________________
#154 (permalink) |
I'm interested. Count me in the group that posted earlier just looking for mild performance improvement without fuel or trans mods.
What, if any, impact does the turbo have on the cat and 02 sensors? Also, is there any change to emissions? I've never owned a vehicle with a turbo, does this CT-26 use engine oil or is it an integral oil system? If it uses engine oil, I assume oil change frequency would be increased, correct? Node - can we see any pics of your 3.4 truck installation yet?
__________________
Jon 97 4Runner 3.4 * 4.88's * ARB Lockers F/R * ARB compressor * Sonoran Steel numba 1 * 285 BFG AT/KO * TJM 17 * BudBuilt Skids * Stubbs Sliders & BBQ sauce * Irbis out back * Various Electronic Gadgets |
#155 (permalink) |
He hasnt done anything yet becuase he doesnt have access to a truck...sooooo if someone in the Carolina area would contact him...maybe you can be a test bed or something
...hint hint nudge nudge....Also any power upgrade will afect your tranny...cant really get away from that Yes its engine oil like all turbos and if you use the right oil and the right shut down procedure then you dont need to change it as often as people say
__________________
-Johnny --------------------------------- '96 Taco V6 4WD Auto with 262 S2S Cams New 5VZ-FE & 3VZ-E Cams available 5vz-fe Stock CR FI Pistons NOW available! www.sea2skytuning.com Plug and Play EMS! Perfect Power, Hydra EMS, Arias, Pauter, Manley Performance Dealer.... Last edited by Weasy2k; 03-03-2006 at 05:36 PM. |
#156 (permalink) |
Thanks Weasy
Ok, well when I read post #129 and Node said "3.4 rig" I guess I assumed he had a truck that it was installed in. Maybe on a test stand? Anyway, Trans mods: they were only mentioned here on the thread in relation to max output T/C, correct? The TRD S/C installation doesn't need any trans mods, right? I understand if you're looking for 300(+) HP that some sort of mod would be needed, but surely the stock trans can handle 225(+-) RWHP, no? As I stated in the previous post, I'm looking for mild highway towing and hill gains, not to snap axles or pull stumps. Just trying to clarify what exactly you mean for mods. [edit- Weasy - just checked your s2s site - cool Taco project - but not at all what I'm aiming for performance wise] Wish I were a little closer to the Carolinas...
__________________
Jon 97 4Runner 3.4 * 4.88's * ARB Lockers F/R * ARB compressor * Sonoran Steel numba 1 * 285 BFG AT/KO * TJM 17 * BudBuilt Skids * Stubbs Sliders & BBQ sauce * Irbis out back * Various Electronic Gadgets Last edited by 111db; 03-04-2006 at 06:58 AM. |
#157 (permalink) |
No it wasnt installed to anything...he thought he had a test rig but that ended up going south as well as the 3vz-e 3.0L one.
Transmission: At 7psi on the stock s/c your tranny will feel the effects of even that added pressure 240whp can be attained even with the stock tranny. Its when you go full throttle in first to second which really kills the tranny. If you dont race around in your truck then you should be fine as shifting is the biggest issue. Stock output is 160-170whp...maybe N/A route is something you should go? I am going to release a N/A power cam soon for the 5vz along with valve springs. Maybe that would be someting you would be interested in? I have a MR2 that im putting the 5vz in which will be n/a for this year and going FI in the off season I will test my cams out in that engine so you guys can see what the N/A stock with cams is like (no porting or valve work done in this engine)
__________________
#158 (permalink) |
Sure I'd consider a cam as an alternative. Maybe you could start another thread with pertinent info so we don't clutter up this one.
__________________
#159 (permalink) |
there is a fairly large on
S2S 262 cams ![]() Node wont mind he is getting a couple sets from me to test the turbo cams that im making.
__________________
#160 (permalink) |
Whats the latest update? Haven't heard from node in a while. 3 months already?
__________________
SOLD: 99' Sunfire Red SR5 Runner / Single Alpine 12" Type-R with Rockford Power BD1000.1 / Infinity Kappa Tweeters / Hella Projector Fogs / Deck Plate mod / 01' Front Grill / Sport Edition Hood with Scoop / Black Pearl Emblems (not forgotten though...) 07' Premium White Pearl Acura TSX / TL Switchblade Key 04' Sebring Silver Honda S2000 / Enkei Gold RPF1 17" 17x8 front / 17x9 rear |
#161 (permalink) |
Can we assume that there's nothing going on?
#162 (permalink) |
I agree
__________________
#163 (permalink) |
yes, for now...
I plan to start designing a manifold this s[pring once the v6 mr2 is done and my truck is then down for summer.
__________________
#164 (permalink) |
Has Node made any progress either?
__________________
- Jamie 1996 4Runner SR5 4X4 Auto Deckplate Mod, Hayden Tranny Cooler, Amsoil Air Filter, OME 881/906 N86C/N91SC Lift Best OBD II scan tool I have used!. .....and I am AMERICAN! |
#165 (permalink) |
As far as i know from talking to him, no he has focused on his V6 projects/school work. He may be going back to doing a turbo kit once he isnt so busy.
This of course is from me talking to him...
__________________
#166 (permalink) |
Any Progress???
__________________
Looking for the perfect truck after toyota bought back my tacoma!! O6 Tundra Double Cab 4x4 99 4Runner Blake Joseph Born 12/08/08 GOT MARRIED 10/27/07!!! |
#167 (permalink) |
If anyone's interested theres a guy that finished developing a turbo kit for the 3.4 on customtacos.
__________________
#168 (permalink) |
I too am working on a couple kits for the 5vz this summer once my car is done and the truck can rest.
Turbo and s/c kits...
__________________
#169 (permalink) | |
Sponsoring Member
Quote:
Got a link? C'mon Johnny!
__________________
~ Mark '96 4Runner Limited S/C MI - 370cc injectors, Air! horns, Airaid MIT, ATS A-arms, 285/75/R16 BFG MTs, Bored TB, Brembo slotted, Cobra 75 WXST, Deckplate, Downey headers, Hayden cooler, IPT valve body, Level 10 torque convertor, Meanstreak exhaust, OME/OME rears, On-board PC (XM, Nav, WiFi, etc), Port 'n Polish, Remote Start, SAW fronts, Hilux console, SMT-5, Stubb's sliders, Supra MAF, TJM-17, 2.0" pulley, Viair 450c, Walbro 190, Weasy2k cams |
#170 (permalink) |
No its not gadget. Its some guy with the name speedfactory206. Here is the thread.
http://www.customtacos.com/forum/showthread.php?t=61280 Here is the actual post with the completed pictures of the turbo in the runner. http://www.customtacos.com/forum/sho...&postcount=193 The guy says that production on the kits can start in a bout a week? And he says they're just about a little bit more than a supercharger.
__________________
#171 (permalink) |
crazy as hell! nNice kit...
__________________
#172 (permalink) |
I want one!
__________________
#173 (permalink) |
Hello!
My 4runner is the one that SpeedFactory is using for the development of the turbo kit for our 3.4L engines. This one above is actually the system he designed for his tacoma. The kit on my runner has a front mounted intercooler and a smaller sized turbo. I will post build-up pics and descriptions in a new thread right now.
__________________
- 1999 4Runner Highlander Edition - Turbonetics BB T3/TO4E TURBO - URD Fueling - 3 Inch Turboback Exhaust - 16x8 Volk TE37X - OME Lift |
#174 (permalink) |
right on...that is awsome work!
cant wait to do that on the 5vz mr2 im working on with the new turbo cams
__________________
| Tags |
| 1mz, 31l, 34, 34l, 5vzfe, flange, fwd, kits, manifold, supercharger, t3, toyota, turbo, turbocharger, v6 |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| turbo manifold | frm_808 | General Vehicle Related Topics (Non Year Related) | 5 | 05-09-2007 12:15 PM |
| turbo manifold for the 3.4? | alexe | 95.5-2004 Tacomas & 96-2002 4Runners | 2 | 02-19-2007 07:59 PM |
| Turbo Manifold | RD1970 | The Classifieds GraveYard | 5 | 12-28-2006 08:30 AM |
| 3.4L Turbo Manifold 5vze : Where to buy? | 98whtLmTD | 95.5-2004 Tacomas & 96-2002 4Runners | 14 | 09-23-2004 03:15 PM |
