Fan Problems/Seatbelt retractors
Has anyone had this problem: The dash fan for the heater/ac only works on III and HI. I replaced the switch with one I know works and it does the same thing. What do I check now?
Also, 1st gen front seatbelt retractors must be made by chevy. They do a lousy job of retracting. I took them apart and tightened the spring and they still work half assed. Do later gen retractors hold up any better and do they swap in?
The first gen seatbelt retractors are not very good. I'm not sure if a newer one would swap out or not.
the seatbelt retreactor suck in the first two gens for sure. 90-91 seatbelts are different than 92-95 for sure. Found out the hard way. First gen i don't know about but early 2nd gen belts would be the way to go if you couldn't find a good set of 1st gens at a wreckers. There is also a spring tension adjustment that can be done to the belt retractor online somewhere. Try a google search and see what comes up.
kawazx636
10-06-2021 03:03 PM
runnermedic
13
09-21-2015 05:20 PM
