Fan motor
Old 07-23-2012, 06:40 PM
ARB1977's Avatar
Fan motor
My fan motor started to run intermittently over the past year. For a ten year old truck i guess i cant complain. I had to hit the corner of the glove box to make ot run. Were should i start?
Old 07-23-2012, 06:48 PM
rworegon's Avatar
Check wiring, loose connection, anything in that corner of the glovebox tied to fan......
Old 07-23-2012, 07:31 PM
ARB1977's Avatar
Originally Posted by rworegon
Check wiring, loose connection, anything in that corner of the glove tied to fan......
Thanks for the reply. Do i need to drop the glove box?
Old 07-23-2012, 07:37 PM
rworegon's Avatar
On my '95.5 Tacoma, the fan is attached with 3 screws that can be reached from the passenger floorboard. Is the '02 fan up higher? The glovebox door only has a couple of screws on the bottom holding it on.
My fan is postitioned the same as this...see post 687-690:
https://www.yotatech.com/forums/f200...1/index28.html
Old 07-23-2012, 10:17 PM
ARB1977's Avatar
Awesome. I've heard people taking apart the motor. Is it that hard to do.
Old 07-24-2012, 03:48 PM
ARB1977's Avatar
I did find the fan motor, took it out and to my surprise it looked almost brand new. Just a little dust on the plastic blades. Almost wondering because how low it sits the connector got loose from passengers feet.
coryc85
09-09-2015 06:24 AM
RobotMoose
Diesel Swaps
08-02-2015 11:00 PM
jackiebrownia
07-20-2015 09:02 AM
1996Taco
07-20-2015 12:02 AM
zd92655
07-05-2015 04:25 PM
Quick Reply: Fan motor
