YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 03-15-2005, 07:59 AM   #1 (permalink)
Send a message via AIM to aNUT
Fan Clutch Question 3.0 V6
I'm reassembling my motor after a full rebuild (spun bearing) and am trying to determine if my fan clutch is bad. It takes about as much torque as opening a new jar of spaghetti sauce to turn the drive plate while holding the fan still. Is this normal, or is the fan clutch frozen. It's about 55 degrees here. Thanks.
aNUT is offline
Sponsored Links
To remove this ad, register today!
Old 03-15-2005, 11:35 AM   #2 (permalink)
Staff
Yoda's Avatar
Sounds about normal. The real test is while it is running.
Does it dis-engage when cold?
Does it engage when hot?
Does the bearing have any play in it? If so, replace it.
__________________
David
TLCA 14788
71 Landcruiser FJ-40 TBI 327, TH-350, Warn 8000, disk axle swap.
76 Landcruiser FJ-40 project/parts (haven't decided)
Yoda is offline
Old 03-15-2005, 11:40 AM   #3 (permalink)
Cebby's Avatar
Send a message via AIM to Cebby
If it's bad, might I direct you to the classifieds here.... SOMEONE has a fan and clutch for sale...
__________________
UZswap.com
A site dedicated to sharing info for swapping the Toyota/
Lexus UZ (V8) engines into Toyota Trucks and 4Runners.
My 4Runner
1993 4Runner, 1UZ (V8) auto dual ultimate crawler, double locked, 35's on beadlocked SR5 alloys,
low lift, hacked fenders, tubbed firewall, custom armor
TOOLandFAB.com
A discussion forum dedicated to tools, fabrication & workshops. See my JD2 Bender Hydro Conversion
Cebby is offline
Old 03-15-2005, 02:43 PM   #4 (permalink)
kevin444's Avatar
Send a message via AIM to kevin444
A clutch fan is supposed to have some resistance when you try to turn it by hand. If its too smooth and easy to push than it too hard. But i guess temperature can also take its toll. Only way is just to turn it on and find out.
__________________
02 4runner conversion complete!
kevin444 is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Question on fan clutch scrid 86-95 Trucks & 4Runners 0 11-12-2006 08:41 AM
Solid fan and remove fan clutch?? riceburner 84-85 Trucks & 4Runners 7 07-09-2006 06:55 PM
2cnd gen V6 A/C condensor fan question Marc 95.5-2004 Tacomas & 96-2002 4Runners 11 07-18-2005 11:36 AM
Stock clutch fan question???? PirateFins 95.5-2004 Tacomas & 96-2002 4Runners 4 05-13-2003 11:19 AM
Fan Clutch Biker Carl Maintenance & Repair Archives 3 12-09-2002 06:10 PM
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
