Factory Foglights on a 1997 4Runner?
Old 12-19-2005, 10:39 AM
mjwalfredo's Avatar
Hi,
Tried searching but came up with nothing. I have a 1997 Limited 4Runner that I bought used. I always thought the foglights that came with it were from the factory but... I cannot find the relay for the foglights in the fuse box. On 1999 and later 4Runners, I know there is a label for the foglight relay on the box cover. So my question is, were the foglights on my 1997 retrofitted? Did foglights even come from the factory on the 1997 model? If they were retrofitted, I will have to search for the relay somewhere in the engine bay right?
Thanks a lot Yotatech!
-Mark
Old 12-19-2005, 11:05 AM
lee
lee's Avatar
are they square? a photo would help.
Old 12-19-2005, 12:36 PM
mjwalfredo's Avatar
Yeah, they are the square Hella's that you see on just about every other 3rd gen 4Runner until 1999.
Old 12-19-2005, 03:04 PM
mjwalfredo's Avatar
In case anyone cares...
I am now under the impression that I have a retrofitted set of foglights. I found a separate relay and fuse for the foglights. Also, the power for the switch is tapped with a scotchlok on the headlamp switch wire.
If the wiring is pretty thick gauge and I have a 30 amp fuse, does anyone think that I could run 100w bulbs in the fogs? Would the fuse protect me from the wattage doing too much damage?
Old 12-19-2005, 08:04 PM
SLC Punk's Avatar
I believe that the fogs were a dealership installed option. I installed the "Genuine Toyota Foglights" and the relay and fuse was separate.
Old 12-19-2005, 08:26 PM
Fink's Avatar
If they are the stock fogs I would run what came in them, if they are aftermarket then they MAY be able to run it but verify the wiring, fuse and all connections can handle it.
Fink
Old 12-19-2005, 08:45 PM
fustercluck's Avatar
These were a dealer installed option.
HUTCHSTACO's Avatar
you might even melt the light, 100 watts killed my fogs, they were piaa's though
Old 12-29-2005, 03:47 PM
Mbretl's Avatar
Foglights
I have a 98 runner. The relay is on the drivers side fender. You may want to move the battery out to get to it easier. Lights and wiring harness can be purchased at Rallylights.com . The lights are pt# HL65060 and interchangable @ $60 each. Their contact info is below is taken from a recent order I made. They should be able to give you any part you need.
If there are any questions, give us a call at 610-944-3233, 10:00am to
5:00pm Eastern Time, Monday through Friday. Outside those times, leave a
message and we'll get back to you when we can. You may also email us at
mail.mosports@verizon.net -
Good Luck -
bigjstang
08-25-2021 12:41 AM
06-01-2021 01:51 PM
icentropy
09-16-2020 02:47 PM
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
skoti89
07-08-2015 12:05 AM
Quick Reply: Factory Foglights on a 1997 4Runner?
