exhaust fumes
Old 01-27-2004, 07:36 AM
lee
lee's Avatar
exhaust fumes
the other day it was REALLY COLD (-13 with windchill) and i was late for work in the morning.
typically, i let the engine idle for a while and just sit in park letting it warm up and giving the oil time to circulate (at the absolute minimum 30 seconds, max 5 mins), and ive been really good about it.
however, this one morning, since i was running late i just turned it on, shifted into drive and went. :pat: the truck sort of coughed (but not really.. hard to explain) and i noticed i was emitting fumes from the tailpipe like i was burning oil (seen this on older pos's).
i drove two blocks with it still happening, then it stopped... and has never happened again.
is this because i just started and went and it was cold, or should i be concerned?? What did this??
Old 01-27-2004, 08:20 AM
loosehead's Avatar
Lee-
I would guess it was just running rich as the ECU should be sending the engine more fuel for a cold start...so there was probably just some unburned fuel coming out with the exhaust. I would only worry about it if it becomes a persisitant problem. If you have ever owend older carb'ed vehicles, it wold be similar to the choke staying closed while you try to excellerate and the engine not getting enough air in the mix.
Old 01-27-2004, 08:38 AM
rimpainter.com's Avatar
I agree with Jayson. Sounds like it didnt like you rompin on it cold.
Old 01-27-2004, 08:53 AM
Phil's Avatar
Yep, you always need to let it warm up at least some when it's cold.
-13 windchill is nuthin. Metal doesn't care about the wind. It was -31 F (-45 wc) this morning here. I have to admit, it was kinda chilly.
Old 01-27-2004, 08:57 AM
cubuff4runner's Avatar
I you sure it wasn't just water vapor? If you notice when it is very cold all cars will emit a lot of water vapor or steam into the air untill they warm up. You probably never notice it because the vehicle is warm when you take off.
Old 01-27-2004, 09:03 AM
lee
lee's Avatar
no, it wasnt vapor, it was blue smoke..
hey, the car has been running great since, though ive decided (after much -ing to myself) that id rather be late!
thanks for the calming words of wisdom.
Old 01-27-2004, 09:13 AM
Maybe since it was so cold the metal had shrunk enough that some oil was able to pass by the rings untill the motor heated and expanded.
Old 01-27-2004, 09:23 AM
zedex's Avatar
Blue smoke is usually burning oil.
Black smoke is unburned fuel.
White smoke is antifreeze.
Grey smoke is your tires.
Blue smoke on start up could be valve seals, valve guides,piston rings. Keep your eye on it. Might just be a fluke thing.
Old 01-27-2004, 10:59 AM
damn that's cold
I don't know bout you guys, but it's a nice 75 degrees here in so cal.
Old 01-27-2004, 11:03 AM
tenfourtyeight's Avatar
Re: damn that's cold
Haha, damn striaght. How many of you northern guys washed you truck yesterday? I did.
:beach:
Old 01-27-2004, 11:13 AM
Phil's Avatar
Re: Re: damn that's cold
I did too. It was dirty. What, you think we never wash vehicles in the winter?
Old 01-27-2004, 11:33 AM
zedex's Avatar
75 degrees? yikes.
-11c,19F. here today. Blowing blizzardy conditions. With the wind chill factored in according to my calculations about -164C. Wont be washin the truck today.
Old 01-28-2004, 04:23 AM
Re: Re: Re: damn that's cold
Feels like summer here and I'm still scared of rain, still got a dirty truck
Old 01-28-2004, 04:27 AM
SLC Punk's Avatar
:beach:
I did on Saturday. I dried off everything and my doors were still frozen! Then to top it off, it snowed 5inches on Sunday, so my vehicles are dirty again! :pat:
Old 01-28-2004, 04:35 AM
lee
lee's Avatar
i wash my truck at minimum every weekend, at most every 3 to 4 days.
i hate salt. i especially hate salt on my paint reaching all the way up to my windows.
Old 01-28-2004, 05:47 AM
Phil's Avatar
In the winter, I use a stick of white grease on the seals and keep the locks lubed. I rarely have problems.
Old 01-28-2004, 06:00 AM
What are you guys talking about?
Old 02-02-2004, 10:43 PM
In the winter I usually get a tan while washing my car.
Steven.m.paulk
06-07-2020 10:45 AM
the_supernerd
10-01-2015 09:20 PM
voiddweller
09-28-2015 11:21 PM
Keithstoyota
09-27-2015 07:29 AM
Quick Reply: exhaust fumes
