exhaust and cat questions - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 01-16-2007, 07:10 PM   #1 (permalink)
so, i've searched and found that the normally aspirated 3.4 v6 seems to like a 2 1/4" exhaust, and the supercharged engines like a 2.5" exhaust.
is there going to be a drawback to putting on a 2.5" exhaust in prep for a supercharger that has yet to be purchased (and may or may not really make an appearance), or will my power and mileage suffer?
I also wanted to find out if there is any problem with ditching the dual cat setup and going with a single high effeciency unit? my truck is a california emmission spec (although not in california??) and I realize that it will probably set a check engine light, but that will be remedied by the urd o2 signal piece.
any other input for a header/cat/exhaust combo would be greatly appreciated, as my cat is on its way out and I figure nows the time to do the whole system, rather than pieces that may or may not work together.
ETA: the rig is a 00 4runner sport, 4X4, 5-speed, 95k miles.
fullmann is offline
Old 01-16-2007, 07:33 PM   #2 (permalink)
kevin444's Avatar
Send a message via AIM to kevin444
Your going to lose some low end tq going to 2.5 piping for the time being. Your going to lose even more tq getting rid of the cat since that truck was tuned for cali emmisions and running 2 cats originally. Let me know how ur cat thing goes. I was planning on test piping the 2nd cat in my 4runner along with the urd o2 simulator.
kevin444 is offline
Old 01-16-2007, 07:40 PM   #3 (permalink)
TRDatVT's Avatar
Send a message via AIM to TRDatVT
I currently am running the the supercharger with NO cats on my california emission truck... runs much better up top and no noticable loss in low end power... needs headers though!
__________________
1999 4 Runner
9.9 sec 1/8 mile on 7 psi and fuel injectors only (NO Alcohol) weak tune!
TRD Supercharger, Alcohol Injection, Walbro fuel pump upgrade, Custom 2.5" stainless exhaust, 3" Tundra/LC Coil Lift, 1.5" 4Crawler BL, 305/70/16 Mickey Thompson MTZ's...
Next: HID Bi-xenon Conversion, Tundra brake upgrade...
TRDatVT is offline
Old 01-16-2007, 07:50 PM   #4 (permalink)
kevin444's Avatar
Remember you are supercharged
kevin444 is offline
Old 01-16-2007, 07:58 PM   #5 (permalink)
Elkaholic's Avatar
Send a message via AIM to Elkaholic
As for it being tuned to Cali standards couldnt he dump the cats then just retune using more URD goodies?
Elkaholic is offline
Old 01-16-2007, 08:02 PM   #6 (permalink)
kevin444's Avatar
Quote:
Yup,
cali standards= power robbing
kevin444 is offline
Old 01-16-2007, 08:19 PM   #7 (permalink)
Elkaholic's Avatar
hmmm then I might need to try this someday, since I was thinkin about buying the tuning supplies anyways
Old 01-16-2007, 08:28 PM   #8 (permalink)
rimpainter.com's Avatar
Guys, it would be a good idea to chill on the "ditch the cats altogether" talk. Let's get back to the original question(s). 2.5 should be ok for now. I assume you have already done your research on the fuel/timing mods needed to make the 3.4 run properly (and safely) with the SC'r, correct? Because I will tell you one thing, exhaust won't mean squat if that thing is running lean all over the place (which it will if you don't get a fuel/timing kit on there) and the engine blows.
rimpainter.com is offline
Old 01-17-2007, 10:05 AM   #9 (permalink)
Quote:
unfortunately I do know that I will hafta spend the extra dough for the fuel/timing mods with the s/c. what I was mostly interested in was the potential drawbacks to putting a 's/c ready' 2.5" exhaust on a vehicle without the actual s/c. also wondering if dumping the second cat is gonna hurt or help. I dont need to worry about emissions stuff as where I live is not regulated. more along the line of what the truck will work best with, I also dont want to be 'that guy' and drive a pollution creating machine when I dont have to, especially if the truck runs better with all the emissions stuff intact. Im currently getting a pretty regular 20-21mpg with the ethanol/winter gas, I was getting 22-23 with regular non winter gas.
I guess im really trying to not have to spend $2k+ for a factory cat(s) replacement without any other exhaust stuffs. when I can hit up my local muffler shop and spend $500 for new cat(s) and full system all the way back, and be better equipped for a possible s/c upgrade in the future.
fullmann is offline
Old 01-17-2007, 10:25 AM   #10 (permalink)
Sponsoring Member
midiwall's Avatar
Quote:
Like Christian said, you'll be fine... The power will drop a bit, but it'll come back up nicely when you put the SC on. _DO NOT_ put on headers without an SC. I made that mistake.
What's your timeline from the exhaust to the SC?
Quote:
...also wondering if dumping the second cat is gonna hurt or help.
Don't pull the 2nd O2 sensor. The ECU needs one in front and one in back.
Quote:
I guess im really trying to not have to spend $2k+ for a factory cat(s) replacement without any other exhaust stuffs. when I can hit up my local muffler shop and spend $500 for new cat(s)...
Ummm... dude, $56 delivered, and they're highflow:
http://search.ebay.com/Carsound-Magn...ytic-Converter
Be sure to buy the right size.
__________________
~ Mark
'96 4Runner Limited S/C MI - 370cc injectors, Air! horns, Airaid MIT, ATS A-arms, 285/75/R16 BFG MTs, Bored TB, Brembo slotted, Cobra 75 WXST, Deckplate, Downey headers, Hayden cooler, IPT valve body, Level 10 torque convertor, Meanstreak exhaust, OME/OME rears, On-board PC (XM, Nav, WiFi, etc), Port 'n Polish, Remote Start, SAW fronts, Hilux console, SMT-5, Stubb's sliders, Supra MAF, TJM-17, 2.0" pulley, Viair 450c, Walbro 190, Weasy2k cams
midiwall is offline
Old 01-17-2007, 10:23 PM   #11 (permalink)
what happens with the headers and no SC??
Im not sure what the timeline between exhaust and SC is, just kinda toying with the idea of the charger right now but I dont want to buttonhook myself in the future by having to re-exhaust my truck.
will the ecu still need two cats between its two sensors, or will one of the high flow units off of ebay work good enough? I know the truck came factory with two, but I kinda figured it might be overkill, and toyota covering their a$$ when it comes to EPA guidelines.
fullmann is offline
Old 01-17-2007, 10:36 PM   #12 (permalink)
Sponsoring Member
midiwall's Avatar
There's not enough back-pressure, which reduces the scavenging effect (getting the exhaust out of the cylinder), which has the net effect of dropping your power band by about 800rpm. That might may you think "Oh WOW... LOW END TORQUE!" but it doesn't work that way - you end up with a boggy engine because of the exhaust not clearing the cylinder before the next intake stroke.
I made this mistake... I drove like that for almost a year. It _sucked_.
Well, it's not Toyota CYA, it's Toyota having to meet the California _STATE_ emissions guidelines.
If you have two cats, then that truck was originally delivered in (or destined to be delivered in) CA. You need to search around the forum for folks that have gone through this. It's not pretty and it may require replacing the ECU with a non-CA version. There are a couple of threads here from about 9 months ago (I think) where people have documented the experience.
There are O2 simulators out there that have worked for some people, but mostly not. There are people that have made it through this, but there are as many people that are still throwing MIL codes every time they start the truck.
Search on "two cats", "mil cat", "cel cat"... that sort of stuff.
__________________
~ Mark
midiwall is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
cat back exhaust andrew241 86-95 Trucks & 4Runners 26 11-13-2007 10:12 PM
Borla Cat-Back Exhaust, how is it? petros 95.5-2004 Tacomas & 96-2002 4Runners 11 07-28-2006 11:20 AM
cat back exhaust? mnm3783 03+ 4Runner/GX470, & 05+ Tacomas 2 03-20-2006 12:12 PM
Questions on 1st Gen 3.0 V6 aftermarket cat and exhaust BNK 95.5-2004 Tacomas & 96-2002 4Runners 2 06-23-2005 12:51 PM
Exhaust-Cat Converter Question 4Runner4Christ 95.5-2004 Tacomas & 96-2002 4Runners 12 10-15-2004 09:31 PM
2009 InternetBrands, Inc.
