engine won't start - help!
Old 06-09-2004, 12:07 AM
grtcrowd's Avatar
Question engine won't start - help!
Just finished replacing the headgasket on our 93 22RE. We had decided to do this after the truck ran slightly hot, and all indications were the gasket was blown. Once into the engine, it appeared the only problem we had was on the intake gasket, not the head gasket, but replaced anyway (since we were already there!). However, the truck was running fine at the time! Relatively smooth idle, not smoking, knocking, pinging or anything that appeared life threatening.
Now can't get truck started. Have checked timing, electrical connections, fuel, vacuum line, etc. Engine turns well, appears to have good compression, etc. Any other suggestions?
Old 06-09-2004, 02:30 AM
Dr.Jeckyl's Avatar
are you 180 degrees out of timing? in other words did you maybe put the distributor back in 180 degrees backward? check for spark + fuel + compression
Old 06-09-2004, 03:39 AM
grtcrowd's Avatar
Already checked that....thanks
Old 06-09-2004, 04:23 AM
gwhayduke's Avatar
Check your fuses. You may have blown one when you reconnected the battery.
Old 06-09-2004, 05:41 AM
grtcrowd's Avatar
Checked the fuses.....they're o.k. Have checked valve adjustment to make sure they weren't too tight. Verified electrical connections on the intake. Still confused!
Old 06-09-2004, 08:29 AM
gwhayduke's Avatar
Ok... time to start all over and begin rechecking. All it takes is spark, fuel, air and all need to be at the right time. So start by checking spark...then timing, then fuel...etc. Tedious, but I usually find my problems when i go back through everything systematically.
Old 06-09-2004, 09:16 AM
mastacox's Avatar
Out of gas
Ok, I'm not helping...
Old 06-09-2004, 09:29 AM
rimpainter.com's Avatar
Does it turn over, but will not catch?
Old 06-09-2004, 09:30 AM
flecker's Avatar
Location: White Mountains, Arizona (Yes it does snow in AZ)
Like said above recheck everything, it's easy to miss a ground or knock one off. Check the afm too if you unplgged it. You can also pull the ecu fuse and reset it... pull it for about 5 minutes and re insert it. You got the timing right? 1 3 4 2 off the dist. cap?
Old 06-09-2004, 05:41 PM
grtcrowd's Avatar
Thanks for all the good suggestions. While we had already checked for fire on the plugs, apparently the plugs had fouled during a backfire. Replaced the plugs, it works fine.
Thanks all!
Crazychris1871
06-27-2016 10:38 AM
Sandman
07-23-2015 08:15 PM
aciorba23
06-29-2015 04:18 PM
newzingo
06-24-2015 01:50 PM
Corey
06-10-2002 04:23 AM
Quick Reply: engine won't start - help!
