Engine Wiring HELP - Wires came out Connector
THE PICTURE IS NOT MY ENGINE JUST A REFERENCE PICTURE FOUND ON HERE.
*EDIT* I think its the cam position sensor and that's where it plugs into the harness. There is two blue "grommets" where the wires plug into the connector (the wires coming from the engine harness NOT the Cam Position Sensor). Can someone double check in their engine bay and possibly see the colors of those wires and tell me what they are. *EDIT*
I was changing my Valve Cover Gaskets (before seeing that it seems common that the bolts just come loose and I could have just tightened them) and on the passengers side it seems that the wires somehow pulled out of the connector indicated in the picture (Orange Circle).
Can anyone tell me what the connector is for and maybe even the what color goes into what side of the plastic connection (I have a blue and yellow wire).
No damage was done to either the wire or connector, I just need to put them back and do not know the orientation or what it is for.
Thanks!
Thanks!
steve miller
10-10-2015 01:40 AM
