engine troubles - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 03-12-2003, 04:24 PM   #1 (permalink)
atarinaper's Avatar
engine troubles
Everytime i pull up to a stoplight my engine starts to die, and i have to give it gas to keep it from dying. Its really annoying me. I increased the level of gas being ommitted into the engine by turning the idle screw.
it still keeps wanting to die though.
any suggestions?
__________________
(RIP)86 4runner 4x4,5sp, Red, 22Re, LC engineering street performance header, new leaf springs. (RIP)
94 vw golf
future truck- 81-83 toyota truck or 1rst/2nd gen 4runner/ pickup
atarinaper is offline
Old 03-12-2003, 04:35 PM   #2 (permalink)
CTB
CTB's Avatar
Vacuum leak? Clogged fuel filter? Need to clean the throttle body? These are just a couple options.
__________________
1995 4Runner V6 4x4
CTB is offline
Old 03-12-2003, 04:55 PM   #3 (permalink)
Send a message via Yahoo to guitarsncars
im having the same problem...although i have a new fuel filter, air filter, tb newly cleaned, AND vacuum lines are checking out ok...any clues? right now idles is at around 1300 rpms just idling when in P or N.....rotor, cap, wires, ignitor, coil, distributor, all good/new...hehe...ive done MUCh troubleshooting...only thing i can think of is EGR valve? but 150 a/m!!! woow!
__________________
-Matt
'85 4Runner, 22re, auto
bored .030
R/V stage 2 cam
Hedman Headers
Flowmaster 50-Series
duct-taped back seat
guitarsncars is offline
Old 03-12-2003, 05:09 PM   #4 (permalink)
Send a message via AIM to Salue
What shape are your plugs and wires in? Might want to check those out also. Does it idle rough as well or just drops in idle?
Salue
__________________
'99 4runner SC
'97 Land Cruiser
'87 turbo 4runner...Sold
'91 4runner...Sold
'94 4runner...Sold
Salue is offline
Old 03-12-2003, 06:27 PM   #5 (permalink)
atarinaper's Avatar
idle is hecka rough, and then sometimes it will just drop.
its weird.
thanks for the advice
__________________
94 vw golf
Old 03-12-2003, 06:30 PM   #6 (permalink)
solarcrew's Avatar
:pat:It could possibly be vacuum switching valve(vsv).I think it runs from the egr.On my 87' there are 2 of these mounted on the valve cover.The one closest to the firewall(back of motor)would be the one to check.The one at the front controls the a/c idle up.An easy way to check it is to use a multi-meter.Unplug the wire connecter from the vsv,set the meter to ohms,touch the 2 leads from the meter together and see if the needle moves as far as it can go,if it does,then the meter is set right.Now seperate the leads of the meter.now touch each lead on the vsv with the leads from the meter.If the meter needle buries then the vsv is ok.If not,the vsv is bad.Another way is to take a piece of speaker wire an use it like jumper cables.One end to the battery the other to the vsv.Don't leave it on very long,it could burn up the vsv if its still good.I'd use the meter method if at all possible.The vsv is nothing more than a bunch of thin wire wrapped around that when energized becomes magnetic and opens an air passage.You'll see the 2 vacuum lines going to it.Then again,it could be a stopped up air filter and I wasted everybodies time rambling.Oh well,good luck.
solarcrew is offline
Old 03-12-2003, 06:38 PM   #7 (permalink)
heh..i was toying with that idea....i wonder if its the wiring to the VSV, or the actuator itself....i didnt have this prob before the rebuild...sorry to comandeer your post, atarinaper
__________________
-Matt
bored .030
R/V stage 2 cam
Hedman Headers
Old 03-12-2003, 08:32 PM   #8 (permalink)
solarcrew's Avatar
:pat: Yeah,it could be the wiring also.My motors been acting up during cold starts.I wiggled the wires around the cold start timer and the temp sensor and the idle picked up.So you could check all the wiring.I almost forgot about the air suction valve under the throttle body,beside the cold start timer.It should be closed when the engine is warm.There's 2 ways to check it.With the engine warm,1-pinch the hose going into the asv with a pair of pliers,if the motor smooths out then the valve is stuck open.if the rpm's drop about 50,then it's ok.2-with the engine warm,pull the hose off going into the asv.stick a screwdriver into the hole of the asv.If it stops after an inch or so,then the asv is ok.If the screwdriver goes in pretty deep,then the asv is hung open.I forgot to point out that only disconnect the front hose.The 2 in the back of the asv are coolant lines.If the asv doesn't appear to be working,you can take the front cover off by removing the 4 phillips screws in the front.There should be a spring and a small plastic plate that works as a gate valve.Make sure it moves freely.These things aren't cheap so be careful.Good luck.
Old 03-13-2003, 09:59 AM   #9 (permalink)
Babypig's Avatar
Don't overlook the TPS. It could be out of adjustment. I just went through the same kind of thing and it was the TPS being out of adjustment. It wasn't out of spec but toward the high side of the specs.
__________________
Ironpig2 is a 1990 4runner SR5
95 3.0V6, ARB front bumper, Hella H4 conversion, Hayden Trans cooler, Aisin manual hubs, Drilled headlight bezel, Clinometer, Altimiter, Assorted Camera mounts, JVC double din head unit, Hilux Surf emblems, Bridgestone Revo's, OME 901's , N72f's
"Stay calm, Be brave, Wait for the signs."
Babypig is offline
Old 03-13-2003, 11:55 AM   #10 (permalink)
solarcrew's Avatar
:pat:One last thing on the asv.There's an electrical connection on the back of it.I had to get under the truck to see it.Mine was unplugged after the motor was installed during a rebuild.This connecter sends signals to the computer.Make sure it is plugged in.Good luck!
Old 03-13-2003, 02:07 PM   #11 (permalink)
hahaha..i went through a whole fiasco with *that* plug right after my rebuild..couldnt figure out where the hell it went! but, thanks to some swell e-buds, the connection was located. i love a great ending
__________________
-Matt
bored .030
R/V stage 2 cam
Hedman Headers
Tags
22re, 4runner, 87, air, suction, valve, vsv
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Toyota 3S-FE engine troubles CMD93 Off Topic Talk 4 11-06-2007 11:00 PM
85 wont run, engine troubles thebeast8888 84-85 Trucks & 4Runners 8 06-18-2006 02:46 PM
Engine Troubles 458 93-98 T100s 4 03-18-2006 02:01 PM
HELP! Manual Transmission Troubles- won't shift w/engine running smwells 95.5-2004 Tacomas & 96-2002 4Runners 6 02-08-2003 07:29 PM
cold engine troubles Skydigger 95.5-2004 Tacomas & 96-2002 4Runners 5 09-08-2002 04:46 PM
2009 InternetBrands, Inc.
