Engine Temp Varies.. - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 08-15-2003, 04:33 AM   #1 (permalink)
metal22lica's Avatar
Send a message via AIM to metal22lica
ok guys...my normal engine is a little less that half way. lately down here in FL its been hot, but this just started. my engine temp will go up and down. it use to hold constant. it seems like this only happens when i come to a stop. then once i start to go again..it will cool back down. anyone have any ideas on what it could be? thanks guys.
__________________
SOLD??? Never
1990 Automatic V6 4WD SR5 4Runner
Mods: Downey 1.5 HDs, Aisin Hubs, CD, CB with a 4' Firestik, Husky Liners, Maglite Mod, 2nd Gen Airbox Mod, K&N filter and a Smittybilt Brush Guard with 4 lights.
Next: Rims? Shocks? Exhaust?
PICS
-Corey
metal22lica is offline
Old 08-15-2003, 07:09 AM   #2 (permalink)
mtnfreak's Avatar
Check to see if your fan is slipping. Sounds like it's not moving enough air on it's own to keep the engine cool. Another possibility is the water pump not moving enough coolant. When you come to a stop, put the tranny in neutral and rev the engine to about 2500rpm and see if that helps any.
__________________
89 4Runner, V6, Auto, Some stuff's stock, some's not.
mtnfreak is offline
Old 08-15-2003, 07:24 AM   #3 (permalink)
rimpainter.com's Avatar
Sounds like the thermostat to me.
rimpainter.com is offline
Old 08-15-2003, 09:40 AM   #4 (permalink)
dusty98's Avatar
Do you hear your fan running? When that fan clutch locks and the fan starts turning the truck should be noticeably louder as well as a little less on power.
My fan comes on when I first start it till it warms up, then anytime I run the A/C or sit in traffic.
One way to test it is when the truck get hots, turn the engine off, pop the hood and try to spin the fan by hand. If it freewheels when the truck is hot, the fan clutch is probably bad.
Let us know what you find...
__________________
98 4Runner SR5 4WD, Desert Dune
Revos, Custom mounted Hella 550s, Yakima Rack
99 Corolla, 38mpg.
dusty98 is offline
Old 08-15-2003, 12:17 PM   #5 (permalink)
the fan is running, and i just had the fan clutch replaced. would it have anything to do with the amount of water that is in the over flow tank??
__________________
SOLD??? Never
PICS
-Corey
Old 08-15-2003, 01:01 PM   #6 (permalink)
What matters is the cold level of fluid in your radiator, not the overflow.
When cold, make sure you have sufficient coolant. If you do, move on to the thermostat - I'll bet that's what it is.
Old 08-15-2003, 01:07 PM   #7 (permalink)
ok..sorry to sound stupid..but how do i check the fluid level in my radiator?? i cant believe i am asking this...
__________________
SOLD??? Never
PICS
-Corey
Old 08-15-2003, 01:10 PM   #8 (permalink)
Just take off the cap when the engine is cold, and verify that the coolant is up to the bottom of the neck. If not, mix a 50/50 solution of coolant and Distilled water, and fill it up.
Old 08-15-2003, 01:25 PM   #9 (permalink)
As the car is running, you may be able to feel the bottom hose of the radiator. It should be cooler than the top hose to the radiator. Also try to feel for a vibration in the hose to let you know that the fluid is circulating to the engine.
What kind of coolant do you use?
Have you had your radiator flushed lately?
I read that dex cool crystalizes when it boils off. This can clog up parts of the radiator.
"Cat-O-Leen" is offline
Old 08-15-2003, 01:27 PM   #10 (permalink)
i just had the fan clutch and the radiator replaced when the fan clutch broke and tore up my radiator. this was about 3 or so months ago.
__________________
SOLD??? Never
PICS
-Corey
Old 08-15-2003, 01:35 PM   #11 (permalink)
And these symptoms are just now surfacing? Did you get any kind of warranty where you had this work done?
Sounds fishy that you had this work done and you are getting some cooling system problems...
Old 08-15-2003, 02:03 PM   #12 (permalink)
yeah..this just started to happen. i just went out and fill up the radiator and the overflow tank. i will have to see what happens. i came home from work today and it didnt do it. i got 90 days on the work, but like i said this just started to happen. hmmm...
__________________
SOLD??? Never
PICS
-Corey
Old 08-15-2003, 07:07 PM   #13 (permalink)
Maybe they didn't fill the radiator up all the way. I changed mine out about a year ago. When I did, I had some bubbles in the system that had to work through. Finally the system worked the air into the radiator which made it seem like it was underfilled.
After you run your vehicle and you come to the front, do you smell any anti freeze? Then you would know you had a leak. They could be pin holes where it never leaves fluid on the ground and boils off when you run it.
Hopefully it's the first option. I really sucks being on the road, sitting in traffic and watching that needle go up up up.
good luck
Old 08-15-2003, 07:28 PM   #14 (permalink)
Bumpin' Yota's Avatar
Send a message via AIM to Bumpin' Yota
You probably already know this bro, but don't pop the radiator cap when the engine is hot.... hot steam can f you up pretty bad REALLY quickly.
__________________
3vze, 4x4, sr5, 90, auto, LSD
2x dB Drag World Finalist
2003 Nopi Nat. Street B champ
2004 SBN Street C champ
2004 SBN Advncd NW Champ
2004 Former WR Holder in NW.
SPL: 159.8db @ 42hz
In loving memory of Jamie Riggs 5/15/85 - 10/8/04
Bumpin' Yota is offline
Old 08-17-2003, 05:55 PM   #15 (permalink)
dusty98's Avatar
Another thing to check is the radiator drain valve. Its on the passenger bottom side of the radiator. Last time I had my coolant flushed, they didn't tight it. I left puddles everywhere I went so that was easy to find and fix.
__________________
99 Corolla, 38mpg.
dusty98 is offline
Old 08-17-2003, 06:05 PM   #16 (permalink)
KING's Avatar
Yup, I also have this problem on my '94 PICK-UP.
I don't care though, I let it run hot if it wants to. If it wants to overheat, then I let it do that too.
I've ran tired of trying to find what's wrong with it, and have had no solutions.
I'm about to change my water pump, if that doesn't do it, I'm getting rid of it or throwing it off a cliff.
But I have many more problems that this is like nothing to me.
As I've said MANY, MANY other times, If I was turn off my truck when it's running after a while, and turn it back on, the temp climbs up to three-quarters, then as I start to move, it cools to normal, but that's driven me nuts. I close my eyes everytime I turn my truck off in occasions of that sort.
I'm not a bit happy with this truck; I hate it.
KING is offline
Old 08-19-2003, 09:07 PM   #17 (permalink)
Hmmm....this sounds like the same problem we've had for a while now. Yesterday, I left a post about this.....after many really good responses, I replaced the thermostat AGAIN!
The one I used was from Toyota Part # 90916-03070. (Cost $22.97) We put it on this afternoon, and drove up every serious incline we could find to attempt to get it to overheat.
It seems to have worked! Hopefully, it will continue to do so!
Maybe this will help.
grtcrowd is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Engine Temp Problems?? werm262 86-95 Trucks & 4Runners 6 06-11-2007 05:25 PM
Main heater out rear works engine temp ok skshepherd 95.5-2004 Tacomas & 96-2002 4Runners 3 02-18-2007 09:29 AM
gas mileage varies per state wvuviv30 95.5-2004 Tacomas & 96-2002 4Runners 5 06-21-2004 09:34 AM
engine temp dropcivic 95.5-2004 Tacomas & 96-2002 4Runners 37 11-17-2003 02:10 PM
Temp Sensor / engine missing questions Zecho Maintenance & Repair Archives 0 07-27-2003 02:17 PM
2009 InternetBrands, Inc.
