Engine Restorer
Old 11-21-2003, 12:26 PM
Fink's Avatar
Engine Restorer
Have any of you guys ever used Engine Restorer? I have heard its good for older engines...what do you all think?
Fink
Old 11-21-2003, 12:30 PM
AznSky's Avatar
what happened to the tune up you were getting? I would think that would somewhat restore ur motor
Old 11-21-2003, 12:33 PM
Fink's Avatar
I got the the tune-up done and its running GREAT...I was just thinking it would help prolong the life of the engine and its components.
Surprisingly after all that work...my mileage still isn't up to par....weird.
Fink
Old 11-21-2003, 12:44 PM
AznSky's Avatar
what are you getting? It can't be as bad as my 15 mpg
Old 11-21-2003, 12:48 PM
Bob_98SR5's Avatar
fink,
c'mon now, you've been here too long! search your own question. there are two threads (one of which you started) that addresses your same question and others have given their results.
bob
Old 11-21-2003, 01:07 PM
midiwall's Avatar
One thing to add to what I had said in the other MPG thread is that I've since been pointed to Auto-Rx. It's said to do a much better job than Engine Restorer.
The downside is that it's expensive in terms of how it needs to be "applied":
http://www.auto-rx.com/pages/applications.htm
To save you the counting, if you have over 100,000 miles on the engine, you're going to go through:
  • Two bottles of Auto-Rx
  • Four oil filters
  • Two oil changes
Mark
Old 11-21-2003, 02:17 PM
AK
AK's Avatar
i use it every oil change. the first time i added it i noticed a smother idle.
Old 11-21-2003, 08:37 PM
Fink's Avatar
I wasn't asking if the Engine Restorer would improve my gas mileage.
And yes Toyo...its worse than yours, ~12MPG city.
I was just wondering if it would help renew the parts internally and essentially make everything last longer...
I tried searching but once again could not find a straight to the point yes or no...
Thanks for the replies and suggestions,
Fink
Old 11-21-2003, 10:30 PM
midiwall's Avatar
Originally posted by 4x4Fink
II was just wondering if it would help renew the parts internally and essentially make everything last longer...
Yes, it will. But Auto-Rx does it better.
Old 11-22-2003, 05:35 PM
Fink's Avatar
Thanks guys, I appreciate it.
Fink
icentropy
09-16-2020 02:47 PM
RaginAsian91
Engine Swaps
03-30-2019 09:17 AM
jasonty
41
12-23-2018 01:00 PM
Seattle_Sign_Guy
07-12-2015 12:38 PM
Nickdigg
07-07-2015 06:04 AM
Quick Reply: Engine Restorer
