Engine Problem!
Old Jul 27, 2004 | 02:12 PM
toyota884runner's Avatar
Engine Problem!
OK, i have an 88 4runner 22re 4cylinder 5 sp. after letting the truck sit over night out in the rain. i start it up and the exhaust sounds different deeper than before and and it sputters. this is the first time this has happened in a long time. last time it sputtered while driving in the rain and would almost die. but i replaced the distributor cap and spark plugs and it fixed it. I drove it a short distance and i check my radiator reseriovr tank and it was almost bone dry so i added water to it. the reason this happens is because i have a slow radiator leak along the top seam. what would be causing it to do this?? how can it be fixed?? i have a factory service manual. also what is the pc valve and the maf??? thanks please reply steven
Old Jul 27, 2004 | 02:14 PM
seaflea's Avatar
have you changed the rubber O-ring on the distributer? It acts as a gasket between the dist. cap and dist.
Old Jul 27, 2004 | 02:17 PM
i believe so. see it wasnt doing it when i drove it home in the rain. it did it after it sat all night in the rain.
Old Jul 27, 2004 | 04:39 PM
seaflea's Avatar
sounds like condensation build up in the distributor.
I would also check the PCV valve. If they get clogged they can cause problems too.
Also check the connections from the air box to the throttle body if there is a leak it could be coming from there.
steve miller
Oct 10, 2015 01:40 AM
Yota.Jay
Jul 23, 2015 08:08 PM
Jnkml
Jul 6, 2015 01:20 PM
wilbertd
Jul 6, 2015 07:39 AM
