Engine Management options
Old 06-14-2005, 12:29 PM
Red_97's Avatar
Hey guys, I recently purchased a 97 4Runner, and have been looking at getting a TRD SC for it. My question is what do most people use to tune with? Is there a company that makes stand alones? Thanks for the input.
Ned
Old 06-14-2005, 02:11 PM
CynicX's Avatar
you will find some very good products at www.urdusa.com
you will find some great information at www.gadgetonline.com then click "My 4Runner"
Gadget has been through all the tuning stuff you'll ever need to know...check it out...
Good luck..
Old 06-14-2005, 02:22 PM
Red_97's Avatar
safcs are junk if you ask me. They are pretty much a half assed approach...
Old 06-15-2005, 11:45 AM
Red_97's Avatar
Anyone know any toyota stand alones?
Old 06-15-2005, 01:19 PM
AgRunner06's Avatar
I've heard good things about the FTC to control ping.
Old 06-15-2005, 01:47 PM
midiwall's Avatar
Ummm... what are you expecting to be able to do, modify the ECU tables directly and programatically? I've never seen anything like that for our trucks. By all accounts, the ECU is sealed. The code in the ROMs is encrypted, and you'd have a heck of a time reversing engineering it. There's no external access through the OBD ports like you'll find on other mfg's vehicles. This is why "we" run piggybacks.
If you want that level of control, then you're looking at replacing the ECU with one of the aftermarklet wide-open ones. That's just short of insanity, but I've definitely thought of doing it. Figure on building up your own wiring harness and spending a good amount of time setting up the ECU to deal with the ignition "fun", not to mention the tranny.
If you're reconsidering a piggyback, then there're basically two that people here have experience with, the SplitSecond FTC line and the PerfectPower SMT line.
edit: One more option... There's also the "TRD 7th injector" system, but that's basically there to fix the ping and lean-out issues. It's NOT programmable in any way.
the1998sr5
15
07-14-2020 08:35 PM
msane99
07-17-2015 10:13 AM
rbh261
07-13-2015 12:04 PM
A2theK
07-12-2015 10:46 AM
Vargntucson
07-04-2015 12:15 PM
Quick Reply: Engine Management options
