engine losing power and backfiring/knocking at WOT - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 08-28-2007, 01:10 PM   #1 (permalink)
knemo77's Avatar
Send a message via Yahoo to knemo77
My truck that must last for 100,000 more miles is giving me problems and I was hoping for some good cheap advise to fix her up.
As the title says it accelerates semi-fine till I hit WOT and then it just dies out going to like 3000 rpm and backfiring or knocking.
The idle is also a problem. Every once in a while it will idle real low, start surging slightly and cuts off. If I restart while giving it gas it restarts easy enough and usually doesn't do it again.
Finally, when the engine is cold it will not really accelerate at all until it feels like the computer catches on and changes something. Then it accelerates fine till WOT.
My truck now has 78000 miles and is the 2000 limited. Thanks in advance for any help.
__________________
2000 4runner Limited Auto 4wd
My Homepage
knemo77 is offline
Old 08-28-2007, 01:29 PM   #2 (permalink)
Go to Autozone or Advance Auto and have any codes pulled from the computer. Free for the asking and if its simple, they may replace it while
you wait or at least sell you the part to put in at home.
Appears to be the fuel filter but could be electrical.
SEAIRESCUE is offline
Old 09-02-2007, 09:55 PM   #3 (permalink)
icerunner's Avatar
Exact same thing happened with my runner at 78k, and I'm confident its is aged spark plugs as they should be replaced at 30,000 Mile intervals.
Duel electrodes denso or NKG and stay away from bocsh as the engine says right on it that it requires duel electrodes
good luck
icerunner is offline
Old 09-02-2007, 11:15 PM   #4 (permalink)
86tuning's Avatar
Quote:
Originally Posted by icerunner View Post
Exact same thing happen with my runner, and I'm confident its is aged spark plugs as they should be replaced at 30,000 Mile intervals.
good luck
This is the first thing that I would check. Cheap. Easy.
The correct Denso plugs are K16TR11 and the dealership sells them for less than $20/set of 6.
__________________
- Brian
84 toy pickup
mostly stock
86tuning is offline
Old 09-04-2007, 09:54 AM   #5 (permalink)
knemo77's Avatar
that sounds like the advise I needed.....thanks guys i'll replace those today and see if it helps. I already got a new fuel filter so thats getting replaced as well. I will post as soon as I'm done and tell how it went.
__________________
My Homepage
knemo77 is offline
Old 09-04-2007, 09:59 AM   #6 (permalink)
96redtoy's Avatar
the plug wires should be changed too
96redtoy is offline
Old 09-04-2007, 11:19 AM   #7 (permalink)
hross14's Avatar
Quote:
I wouldnt change the plug wires though until you test them. My 97 plugs wires are still good (162K miles). Maybe the next interval would be a good time. Simple tests--start the engine and turn off the shop lights (in the dark)--look for arcing or sparks. If that happens they are bad. And you can run your hands along them (shop lights on) and see if you get shocked--that is the fun one!!
__________________
Yes, I said "country." America really is a nation, but you couldn't convince those who lead the Democratic and Republican Parties of that. Both parties now see America as nothing more than an economy, a marketplace, and not a sovereign nation. They don't see you and me as citizens of this great nation; they see us as units of labor, consumers and taxpayers.
Yes, I am here to collect my 238$ worth of stock from AIG.
"What do you mean a free market economy doesnt apply to the rich?"
hross14 is offline
Old 09-04-2007, 01:26 PM   #8 (permalink)
96redtoy's Avatar
that is how my dad tought me to check them( i was young and stupid to lissen to him) lets say i learned the hard way that they needed to be replaced.
96redtoy is offline
Old 09-07-2007, 12:29 PM   #9 (permalink)
icerunner's Avatar
leave em in
Quote:
100% CORRECT: My coil packs and wire are great at 140K Do the test 1st to see if there is any arching....I take one look at the coil packs and wires and I say to myself .....
" dam, this yota is built well..."
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
losing power yotarunner96 95.5-2004 Tacomas & 96-2002 4Runners 3 03-29-2006 07:00 PM
Losing power (esp. up hills) even after tune up PSUDawg 86-95 Trucks & 4Runners 10 03-18-2006 12:34 PM
96 Tacoma losing power 96Tacoma Guy Site Feedback 5 12-05-2005 08:02 PM
More Power Without losing Mileage????? deathrunner 95.5-2004 Tacomas & 96-2002 4Runners 4 08-07-2004 02:17 AM
truck losing power Help needed! ranma21 95.5-2004 Tacomas & 96-2002 4Runners 23 10-07-2003 05:28 PM
2009 InternetBrands, Inc.
