engine light on......
Yes, you need to open the hood and locate the little gray cap next to the fuse box. Open it and conect a jumper wire between terminals TE1 and E1
Read this for the info on how to check and clear the codes. http://www.troublecodes.net/Toyota/
Thanks for the quick reply.
I seem to remember a way of checking fuel trim through the diag connector with a DVOM. 2.5v being normal (14.3) /5V being rich running/0V being lean running. Anyone remember the 2 terminals I need to jump??
BTW the codes I pulled are 14 and 25. Ignition signal and lean a/f ratio.
Have a peek at this
http://personal.utulsa.edu/~nathan-buchanan/93fsm/
I was just thinking the other day that it's been a really long time since I've had to do anyhing to my truck but LOF's and brakes jobs (9 years + over 100K). Guess I jixed myself!!
You guys are awsome!! Thanks for all your help!!
ashersullivan88yota
01-18-2022 05:37 PM
06-01-2021 01:51 PM
Johntom240
7
07-13-2015 12:18 AM
madxman21
07-09-2015 10:26 AM
