Engine cutting out
Engine cutting out
I was driving down the highway today and all of a sudden my engine began to cut out & sputter. It did it for about 1/4 mile untill I exited the highway. I drove back home and it didn't do it again. Any ideas what may have caused this or had the same problem?
132,000 miles
Put a new fuel filter on 3 months ago
Put BG44K fuel injector cleaner in 2 months ago.
No new engine work
Already used half of the tank with no problems
Check engine light didn't turn on
I am thinking that the fuel pump could be the problem
Thanks
Jeff
132,000 miles
No new engine work
Thanks
Jeff
My truck used to do something similar. It would cut out for about 2-4 revolutions about a mile after a hot soak start, which never did make any sense. Changing the fuel filter almost completely stopped it, and it hasn't done it for at least 5 months @ 24,000 miles/year. Because of that I never could track it down, and I still don't know if it was fuel or spark related although I do suspect fuel.
Hmmm....My sister's 4runner was doing something similar this past week. She took it to the stealership and they said it was the spark plugs. How long has it been since you've changed the plugs. I noticed that you've got some mileage. If it's been a while I might pull a couple out and check for wear or carbon buildup.
Someone correct me if I'm wrong, but I thought that Toyota fuel filters never needed to be changed. If I'm wrong don't ask me where I heard this 'cause it may have just been the voices in my head.
I changed the spark plugs about 10,000 miles ago, so I imagine that they should still be fine and you do need to replace the fuel filter. I believe Toyota's have higher quality filters than many American vehicles crappy filters which need to be replaced or cleaned on a regular basis, but like any filter eventually it will get dirty and need to be replaced.
rushw
07-18-2015 01:46 PM
crashburnoveride
07-10-2015 06:39 AM
