Engaging an E-locker manually
I have the E-locker third from an 02 Tacoma that I will be retrofitting into my 1990 rear end, and to do so I have to engage the locker. How do I do so manually?
Originally Posted by eric-the-red
If you mean you want to engage the locker to install it just connect the motor directly to a battery
You can engage it with a flat-head screw-driver also. Just take the motor off and you'll see the splines. Just move the arm over to the pinion. You may have to spin a tire to release tension off the arm.
WTB[PacSoWest]: Looking for a electric locking differential motor/ actuator
AaronM
07-08-2015 07:15 PM
