| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Electrical Advice?
#2 (permalink) | |
Upgraded alternator or optima battery *maybe even dual optimas but I'm not too familiar with it*
__________________
1998 4Runner SR5, Surco Safari rack, diff breather mod, Cobra WXST II CB radio, 31" Winston ATs, clear corner/bumper lens, hitch mount backup lamps, PCV catch can. Quote:
#3 (permalink) |
i saw that thread and thats what sorta spawned this thread. should i get a yellow top and upgrade the alt or do a dual battery set-up. What are some good alt upgrade kits?
#4 (permalink) |
yeah, you are def overloading the alternator with that much load, as is evidenced by the lights brightening when you accelerate. Capacitors, optima, probably both would be beneficial. Im sure an electronics guru will chime in with more detailed suggestions...
__________________
TOYOTA|moving forward 1996 3.4 Litre | 4-Wheel Drive | 5-speed Manual Transmission | Magnaflow Exhaust Deckplate | Intake Silencer Removal *MasterDebater*
#5 (permalink) |
thanks msw0085...i have a 1 farad cap...what to do what to do
#6 (permalink) | ||
Quote:
Why would he need a compacitor? All it does is store the voltage not supply it. I can see him using one if he had a system in the truck for the low hits. You might be better off doing a search on it since it's been covered a bunch before. As far as alternators, the 3rd Gens usually talk about putting an MR2 alternator on since it has more amperage and bolts right up as far as i know of. I'm contemplating one myself for mine. Or just recently there is a thread about a dual battery setup. Check in there or search dual battery.
__________________
#7 (permalink) |
Ironmike...do you know the spec on the MR2? Like which model does that alt come from and what is the output? thanks
#8 (permalink) |
Agree with IronMike, you need more supply not more storage. More battery only prolongs the issue. Upgrade the alt or turn off some stuff!
__________________
All my Yotas are gone. Stuff to sell: http://www.yotatech.com/showthread.p...39#post1009839 -Phil |
#9 (permalink) |
but i like all my stuff on.
Is the MR2 Alt decently inexpensive?
#10 (permalink) |
I just did a new stock alt and Im wishing i had have upgraded. with my cd player, lights, tach, and electric fan on there is a big dim.
#11 (permalink) |
http://catalog.drivewire.com/drivewi...art=Alternator
is this the one...it only says 100amps and I thought I read somewhere on this forum that the MR2 had a 170amps * "Get an alternator from a 91+ MR2 the one with the electrohydrolic power steering. Make sure you specify tha you MUST have the one for the power steering model. Those beasts are 170AMS!!! It bolts up (to the 5VZ) but you may have to change the pully though. Im running the MR2 crank pully too so im not sure if the mr2 alternator pully would line up. Go to autozone and order a remanufactured one. Even if you dont trade your old one in for the core you will still save at least $200 Cheers Jim" Anyway, if it is a 100amps will that make a large difference over the stock alt I currently have? |
#12 (permalink) | |
Yeah I was wondering that myself Noel. I am really not sure about what the true amperage is though. The only other problem I can see with the MR2 alt. is the connectors. I have not really researched it much yet so I don't know. Yes it will make much more differnce over stock since I think ours is only like 60 amps max amperage.
__________________
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| clutch solutions? | 91muddog | 86-95 Trucks & 4Runners | 9 | 05-15-2007 03:27 PM |
| p0136 error solutions? | kevin444 | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 05-02-2007 01:22 PM |
| Off Road Solutions | Flygtenstein | Customer Feedback For Vendors | 20 | 09-18-2005 08:16 PM |
| minor problems no solutions | my85runner | Maintenance & Repair Archives | 1 | 05-09-2005 09:52 PM |
| Offroad Solutions | wheelerz | Offroad Tech | 5 | 04-07-2005 08:26 AM |
