Electrical Problem Help
Old Feb 27, 2004 | 07:33 AM
RkyMtn_Toy's Avatar
My 88 4Runner is having a problem I can't figure out. Not always, but quite often, when I press the brake, use turn signal, or turn on lights while driving, my radio cuts out momentarily. I also noticed that the lights sometimes get brighter and that makes it cut out also. And sometimes when I hit a hard bump it happens. Alternator? That's the only thing I can figure. Would the stereo be drawing that much power?
It is aftermarket Sony Xplod with Xplod speakers. I noticed all this on a 3500 mile drive the last week around the country and didn't notice it before. Any help appreciated.
Old Feb 27, 2004 | 07:41 AM
4RUNR's Avatar
Guest
Sounds like a loose connection. I'd lean towards a bad ground. Troubleshooting wiring harness in such an old truck would be a pain so the easiest would be to ground the radio to a new spot and see if it does it again.
Old Feb 27, 2004 | 07:45 AM
growinseed's Avatar
ground to body of head unit
Old Feb 27, 2004 | 07:50 AM
Denk's Avatar
I agree...sounds like something causing a short. Bad ground can sometimes create a gap in the insulation of the wire...so also watch out for that. When I bought my rig, the turn signal fuse would constantly blow until I figured out that the trailer harness wiring was shorting on the rear bumper. I got the ends secured only to have that same fuse keep blowing. I ran the wires and sure enough there was a section of exposed wire shorting on each other. Wiring is a PITA, good luck.
coryc85
Sep 9, 2015 06:24 AM
Yota.Jay
Jul 23, 2015 08:08 PM
v_man
Jul 23, 2015 04:01 PM
Poncho0206
Jul 10, 2015 06:21 PM
AaronM
Jul 8, 2015 07:15 PM
