electric fans - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
New! Use your Facebook to securely log into this site, click logo to login
Welcome to Yotatech!
Welcome to Yotatech,
Old 02-17-2003, 05:31 PM   #1 (permalink)
electric fans
Just have to announce I got the electric fans in. However mentioned them to me in the first place, thank you. I put the fans in today and finished on the wiring except for the connection to the a/c switch. I don't use a/c around here anyways, so I will connect that later, but the fans do really nice. Less sound to deal with when starting up, and they still do a good job cooling down when you need it. Now I can remount the radiator after having to drop it a few inches when I did the body lift. It will be nice knowing my radiator won't be the lowest part on the front of my truck . Anyways, just had to mention this OK? Anyone curious about switching to electric fans, there are plenty of people on the forum here that now how to do this set-up.
__________________
'97 2wd Tacoma, 3.4 V6
Suspension: Fabtech 3 1/2" lift and Rancho RS5000 shocks
Performance: flowmaster muffler, K&N air filter, intake silencer removal mod, elbow and deckplate mod, NGK spark plug wires, flex-a-lite electric fans.
Lighting: Pilot Driving Lights, Sylvania Silverstar Headlight bulbs, Blazer "Ultra-white Series" Fog Lights (there's an oxy-moron), and nifty blue L.E.D.'s here and there
Stereo: All kenwood system, 47x4 deck, component systems up front, 2-ways in rear panels, 10" sub, 600 watt amp.
Miscellanous: smittybilt steps, bushwhacker fender flares, sunpro tach, 3" body lift, line-x bedliner, K&N Oil Filter, Air gate, Viper alarm system, snow tiger seat covers, A.P.C. toyota emblem(blue background) Window Tint:(limo tint on rear windows and extended cab windows, blue chrome tint on visor), fab-tech spare tire mount
2wheeler97 is offline
Old 02-17-2003, 06:07 PM   #2 (permalink)
Sponsoring Member
midiwall's Avatar
Congrats man!
I didn't do the A/C switch either... I may later, but by the time I got the basics done my hands were pretty cold and it was hard to move 'em.
For those folks reading that don't know, the Flex-a-lite control module allows for the connection of a signal wire from your A/C so that the fans turn on anytime that the A/C compressor clutch is engaged. The reason is to be sure sur that there's air moving through the A/C condensor coils (in front of the radiator) which will provide cool (or cooler) air when sitting stopped with the engine running.
It's a decent idea, and considering how much air these fans move, will work a LOT better than the stock fan.
One/two thing(s) against it though... If your driving pattern is basically a lot of moving, then you could end up running the fans a lot more than necessary. As well, remember that having the defroster on will automatically engage the A/C if you have it in order to dry the air. So that would kick the fans on as well.
__________________
~ Mark
'96 4Runner Limited S/C MI - 370cc injectors, Air! horns, Airaid MIT, ATS A-arms, 285/75/R16 BFG MTs, Bored TB, Brembo slotted, Cobra 75 WXST, Deckplate, Downey headers, Hayden cooler, IPT valve body, Level 10 torque convertor, Meanstreak exhaust, OME/OME rears, On-board PC (XM, Nav, WiFi, etc), Port 'n Polish, Remote Start, SAW fronts, Hilux console, SMT-5, Stubb's sliders, Supra MAF, TJM-17, 2.0" pulley, Viair 450c, Walbro 190, Weasy2k cams
midiwall is offline
Old 02-17-2003, 09:27 PM   #3 (permalink)
I am going to have to pull out the truck bible (haynes automotive guide) for my truck and see how the a/c button is setup. Is there a way to wire the a/c switch for the fans just to the button, so that the defroster function doesn't turn on the fans automatically, but the normal a/c will?
__________________
Old 02-17-2003, 09:48 PM   #4 (permalink)
Sponsoring Member
midiwall's Avatar
Quote:
Honestly, I haven't looked at it that close. I have my Haynes right here, but I've had mixed results using it to work through the electrical system. So (honestly) it's not worth my looking at it to give you "their" answer.
The implication in the fan instructions is that they want you to Y into the 12v source for the compressor clutch and use that as the alternate trigger for the fan control module. That of course means that the fans would come on no matter what triggered the clutch.
On my '96, the vent selector control is mechanical (I think it's the same way on your '97) so tapping into the difference between the dash A/C switch being ON and the vent selector being in the DEFROST position could be tricky.
A side note... If you DO Y into the compressor clutch 12v, then that means that you'll have to run a wire from the "engine side" of the install to the "fan side". That means either crossing the path of the belts and the fans, or going down the block to the firewall, across to a fender, up the fender well, and over to the control module. Than can be a bit ugly cosmetically.
With me being up in the PNW, I dun't know that I'm gonna much worry about doing it. You being down in CA, will probably worry about it more.
__________________
~ Mark
midiwall is offline
Old 02-18-2003, 07:46 AM   #5 (permalink)
Depending on what year and model truck or suv you have, you can run the wire from the control box (mine is mounted just under the battery) drop it down to the frame, run it on top of the cross-member, and then up to the a/c. On my cross member there are holes on the top of it, a few of them side by side, so I will just zip tie the wires to that when I run the a/c, if I run it that way.
__________________
Old 02-18-2003, 06:40 PM   #6 (permalink)
trangk's Avatar
Send a message via AIM to trangk
On my install of the FLX-210 I ran the wire for the AC control up to the fuse box and used a mini fuse tap to wire the connection to the AC fuse. My fan comes on with the A/C and it was a very easy install.
trangk is offline
Old 02-18-2003, 07:05 PM   #7 (permalink)
pfdaxe's Avatar
I just placed my order with Summit for my fans. I checked around for the last couple of days and they seemed to have the best price. Checker Autoparts was a couple of bux cheaper but didn't carry the blue ones. I opted for the FLX-210B for mine. These are the blue ones so they match engine compartment/accesories.
Hey Mr trangk:
You stated you wired the a/c wire to your fuse box. The one under the dash or the one in the engine compartmet nest to the battery? Do you have any pics of it??
Thanks!
Paul :fireman:
__________________
My 2000 TRD 4 Runner
My email
pfdaxe is offline
Old 02-18-2003, 07:17 PM   #8 (permalink)
trangk's Avatar
pfdaxe:
I wired it to the one in the engine compartment ... I'll try and get a pic tommorrow (need to get the digital camera back from my friend)
How much extra was the blue fan? I didn't even know they had other colors with the 210 model
trangk is offline
Old 02-18-2003, 07:37 PM   #9 (permalink)
Away
Dr. Zhivago's Avatar
Send a message via ICQ to Dr. Zhivago Send a message via AIM to Dr. Zhivago
Trangk, they all kinds of designer colors!
Check out these lovely pics:
I bought a plain black one from Baxter Auto parts for $233.99 They stock them and it was right down the street from me...
Dr. Z
Dr. Zhivago is offline
Old 02-18-2003, 07:38 PM   #10 (permalink)
Sponsoring Member
midiwall's Avatar
Quote:
Summit only stocks the fan in Black and Blue, but it also comes in Red and Yellow. You can order the alternate colors (i.e., Blue, Red and Yellow) and they run an extra $4.00.
__________________
~ Mark
midiwall is offline
Old 02-18-2003, 08:21 PM   #11 (permalink)
trangk's Avatar
ARGH!
Wish I knew about the red ones and that they aren't that much more expensive. I've seen the colored ones for the Integra/Civic/etc and they always cost SOOO much more. There's just so much stuff in Summit's catalog
Oh well maybe next time
trangk is offline
Old 02-23-2003, 07:17 PM   #12 (permalink)
trangk's Avatar
Not sure if you still need this pfdaxe, but I finally got my camera back from my friend.
Here is how I hooked my AC relay for the fan up. I used a mini fuse tap (available at any auto part store for about $6.00). It has a place for the original fuse and a new fuse for the item you're hooking into it. These things are really nice ...
trangk is offline
Old 02-23-2003, 07:26 PM   #13 (permalink)
pfdaxe's Avatar
Thanks for the pics!
I installed my new grill and installed the fans today. I haven't driven it yet though. I will probably connect to the a/c soon. I looked in my fuse box under the hood and saw the a/c fuse in there. It looks different than your box though(mines a '00). I'll just throw a meter on it and see what side I need to connect to.
Once I drive it I'll figure out where I need to set the t-stat on the control unit. For now, I have it set in the middle(normal)to see how that works.
Paul:fireman:
__________________
My email
pfdaxe is offline
Old 02-23-2003, 07:54 PM   #14 (permalink)
trangk's Avatar
Yeah my 4Runner is a 98 4cycl so the fusebox is different (forgot to mention that). Once you figure out how to fuse your fan though, just get a fuse tap and you'll be all set.
Got any pics of your new grille?
trangk is offline
Old 02-24-2003, 03:34 AM   #15 (permalink)
pfdaxe's Avatar
I'll have pics soon. I finished the grill(at least my part)and now have to take it to the paint shop. I'll also take some pics of my "blue" fans
paul
__________________
My email
pfdaxe is offline
Old 07-18-2003, 07:50 PM   #16 (permalink)
Send a message via AIM to ravencr Send a message via Yahoo to ravencr
So what's the main reason for switching from the stock fan to the electrics? Is there a power gain?
Chris
__________________
http://www.utvrally.com
ravencr is offline
Old 07-18-2003, 08:03 PM   #17 (permalink)
Cebby's Avatar
Send a message via AIM to Cebby
There's supposed to be. The clutch driven fan contributes to "parasitic" power loss. Not sure how heavy the 3G fan is, but basically the fan is being turned by the engine ALL the time - extra resistance. The electric fans come on when the thermostat says (adjustable), plus you can shut it off for water crossings.
Is it documented that it helps provide more power? Not that I've seen anywhere. But, the theory seems pretty sound to me.
__________________
[size="1"][center][color=RoyalBlue]UZswap.com
A site dedicated to sharing info for swapping the Toyota/
Lexus UZ (V8) engines into Toyota Trucks and 4Runners.
My 4Runner
1993 4Runner, 1UZ (V8) auto dual ultimate crawler, double locked, 35's on beadlocked SR5 alloys,
low lift, hacked fenders, tubbed firewall, custom armor
TOOLandFAB.com
A discussion forum dedicated to tools, fabrication & workshops. See my[url=http://toolandfab.com/forum/showthread.php?t=71] JD2 Bender Hydro Conversion
Cebby is offline
Old 07-19-2003, 09:41 AM   #18 (permalink)
Sponsoring Member
midiwall's Avatar
Quote:
Originally posted by Cebby
Not sure how heavy the 3G fan is...
Mine was about 7 pounds, and you also hve to include a bit more for the drag of the blades cutting through the air.
Quote:
But, the theory seems pretty sound to me. [/b]
Yeup... and remember that this is power that's being robbed right at the crankshaft.
The major thing that you feel with the mechanical fan gone is better throttle response since you're reducing the mass that the engine has to push in order to spin up.
__________________
~ Mark
midiwall is offline
Tags
flx210b
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
electric fans for 98 34L jrock 95.5-2004 Tacomas & 96-2002 4Runners 20 03-04-2007 09:11 AM
V8 Radiator, 4 Core BIG & Electric fans. Anubiscougar 86-95 Trucks & 4Runners 13 01-11-2007 06:55 PM
To all you AFI fans.. metal22lica Off Topic Talk 1 01-29-2003 09:09 PM
Contact Us - YotaTech - Archive -
Top
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
2010 InternetBrands, Inc.
