Electric Fan
Old 12-15-2002, 08:25 PM
amdman's Avatar
Electric Fan
What is the difference between an Electric Fan and the regular fan? Why is it an advantage to get an electric fan?
Thanks,
Frank
Old 12-15-2002, 10:32 PM
UKMyers's Avatar
Frank with the regular fan the engine has to work ALL the time to turn it. Even when the clutch on it is disengaged it is still robbing power from your engine to turn the pulley. Also if your hardcore and like to do deep water crossings if your fan is turning all the time it will sling water all over your precious engine compartment i.e. electrics, intake, ect. With the electric fan it works off a sensor and only comes on when the engine reaches a certain temperature and needs the extra cooling. Also most people wire them to a switch that wheel alot so they can turn them off for water crossings and such. I hope this clears up your question.
Old 02-27-2009, 08:31 PM
Ron Helmuth's Avatar
good post
stands the test of time
Old 02-28-2009, 07:47 AM
mt_goat's Avatar
Another advanage of an e-fan is it takes a lot of stress off that fan bracket bearing that has a tendency to fail/explode and cause lots of collateral damage. The stock fan bracket bearing is also very expensive to replace.
Cases of the exploding fan problem:
https://www.yotatech.com/forums/f116...-words-145323/
https://www.yotatech.com/forums/f116...d-part-143611/
https://www.yotatech.com/forums/f116...-3-0-a-105823/
https://www.yotatech.com/forums/f2/1...ollapse-16729/
Old 02-28-2009, 08:10 AM
bipolarandproud's Avatar
It seems like that happends frequently on the v6 engines .
Did they ever have a recall on them ? ?
Old 02-28-2009, 08:15 AM
mt_goat's Avatar
At least on the older ones it did. Don't remember seeing a recall, maybe I missed it though. I had to replace the fan bracket on my 5VZFE but it was in a front end accident and the radiator was pushed into the fan. Tha bracket didn't break but it was making a bad bearing noise.
kawazx636
10-06-2021 03:03 PM
Obmi
10-04-2015 11:30 AM
voiddweller
09-28-2015 11:21 PM
Matthew Perez
09-28-2015 05:43 PM
Project90
09-24-2015 11:40 PM
Quick Reply: Electric Fan
