Elbow
Elbow
Hey guys, i'm in the middle of my first mod; the elbow mod. Does that count? well i got the air box out and i'm about to remove the elbow. Do i jus rip the little rivet thingy holding the elbow in? does anyone have experience with the elbow mod on a 2.7? Also, do i need to reset the EFU? what's the difference between letting the computer correct itself and pulling out the fuse? thanks again guys!
No, no, no. You have to get at if from the fender. Which means taking off your wheel well lining (partially). There should be two 12mm bolts to remove, then you can rip it out from the inside of the wheel well.
so i can't just remove that part of the elbow and have an open hole like in the deck plate mod? darn! :pat: oh well, i guess i'll just do the deck plate mod then.
Hold on a sec. The 2.7 appears to have a different snorkel design. I apologize, I figured it would be the same. If you can get it off without ripping and tearing anything, then you will have succeeded.
Can anyone with 2.7 experience help out?
hay wait i removed the elbow from the air box like you were planning to do i have a 98 tacoma with a 2.7 but it looks to be connected the same way.
i pulled the elbow outta the air box, maybe this is incorect but thats how i did it. . . anyone think otherwise?
i am assuming you have a 2.7 from your post. as for the reseting the efu it will allow your comp to adjust faster.
john
john
ohh yeah be careful i ended up breaking a little bit of the lip off my inlet to the air box nothing big but just be careful.
hay y not do the elbow and deckplate??????
john
john
Well i guess they are kinda the same, to a certain extent. I took out the piece from the fender wall you were talking about 96runner. Here's a pic
Originally posted by 98Tacoma
i didn't remove that peice from my truck. . . didn't make sense to. . . maybe i should. how hard was it to remove?
john
john
Doing both the deckplate and the elbow together won't really gain you anything. Doing the elbow is a reversable change to see if you like it or not, though if you do personally I recommend putting the elbow back on and deckplating it, along with the ISR (unsure how the ISR would go on a 2.7).
pretty easy. I jus removed the 2 10mm bolts and wiggled it out. it may seem like it won't come out...but it will. Attached are some before and after pics. Looks great doesn't it? Thanks for the help, guys!
hay 96 i thought the main point of tyhe mod was to remove the elbow from the airbox to the fender not the fender to the open air. . .
i have the isr on my 2.7 taco may be the same post some pics of your motor so i can see. i will be home in like 3 hrs and will be able to compare and post my pictures of my completed mod.
john
john
Wow, free HP, free magazines, free 24 pk of water, free correction tape; i've never gotten so many free things in my life before yotatech.com!
jay,
looks like you figured it out already but if you want to double check, go to http://www.4runners.org/articles/airbox
theres been debate on the effectiveness (or lack thereof) pulling the EFI fuse. me? i just pulled it b/f installing. i noticed a differnce but then again, it might be all in my head.
bob
bob
john
john
