EGR valve gaskets: 2.7L 4runner
Old 07-09-2010, 06:11 AM
profuse007's Avatar
Just replaced the mini header and wanting to clean out the egr a bit while I am there. I only took off the EGR pipe, not the valve yet.
There are three gaskets:
1.exhaust to pipe
2.pipe to EGR valve
3. EGR valve to intake
Do they use same felpro gasket(#70961)?
autozone and oreilly also have another gasket(#70410) that is weird looking, what is that for?
Old 07-09-2010, 06:30 AM
profuse007's Avatar
anybody make their own gasket? I just order some mr. gasket 10"x10" exhaust gasket material to cut my own, for small application.
Old 07-09-2010, 06:04 PM
pendrag's Avatar
I need to do the same thing eventually. Can you describe anything you had to remove to get the pipe off? It looks like a really awkward job.
Old 07-15-2010, 03:29 PM
NwRunner's Avatar
Its pretty simple to get off. If i remember correctly both EGR pipe gaskets are the same, but the EGR to intake gasket is different. Just order them through a dealer, much simpler and not that expensive.
As for how to get the pipe off. Theres 2 bolts that attach it to the manifold and 2 bolts that attach it to the EGR unit. Unscrew those then go behind the block and remove the bracket that holds the pipe to the block (1 bolt). They are all 10-12mm
Old 07-16-2010, 08:30 AM
profuse007's Avatar
well, I cut out a gasket, exhaust grade. It was the best way for me as far as time is concern. cost me 7bucks for 10"x10" sheet.
06-01-2021 01:51 PM
09-04-2015 09:27 AM
razorman8669
07-12-2015 12:13 PM
87blyota
07-10-2015 04:31 AM
Gamble_STi
07-07-2015 07:54 PM
Quick Reply: EGR valve gaskets: 2.7L 4runner
