EGR help
Old 07-07-2004, 02:17 PM
Tokez420's Avatar
EGR help
whats good to clean out the egr?
Old 07-07-2004, 11:24 PM
Maddog's Avatar
Thats a tuff one .I dried to clean mine the other day & the only thing that did anything was a screwdriver(flathead) .It was scraping off large amounts of black stuff.but i doubt this was very effective.
Old 07-08-2004, 08:27 AM
PirateFins's Avatar
I've read on other boards about using brake fluid to clean them. Pour it in and shake it around, let it sit and dump it out.
Old 07-08-2004, 01:24 PM
Tokez420's Avatar
through the whole assembly with valve, or just the piping?
Old 07-08-2004, 06:25 PM
Maddog's Avatar
Hey I just pluged the vacuum line that comes out of the top of the Egr,I wanted to see if this made any differance,then i could assume that my Egr was hadit.Anyway you would not believe the change,Throttle response has improved out of sight.It pulls up to speed much easier,Less pedal is needed(im barely touching it),all & all its just going heaps better.I think i might leave it pluged.
NB. Remember if you want to try this ,you need to take the line off the Egr ,leaving it on the vacuum piping.then seal the loose end of the line.I used one of those little screws that you get with DIY elctrical light switch's or Plugs( house ).It was a perfect fit.
Old 07-08-2004, 07:01 PM
Tokez420's Avatar
oh, i need to clean it to pass smog :cry:
splangeland
04-06-2024 08:14 PM
kawazx636
10-06-2021 03:03 PM
Longbed 90
10-19-2015 11:05 AM
accuracy
09-20-2015 07:44 PM
Boomer8404
09-10-2015 09:01 AM
Quick Reply: EGR help
