| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
ect pwr button
#2 (permalink) |
Its only available on automatics as i have it on my runner too. All it does is lengthen the shifting points for the transmissions so you can get more out of your engine. This will lower your fuel economy by a bit also.
__________________
1989 Toyota 4runner Special Edition - Rebuilt 22re bored .20 over 4.30 gears, - Magnaflow Performance Exhaust with Magnaflow Hi Flow Catalytic Converter, Monroe Sensa-Tracs Shocks all around, 4runner AALs, Custom Checkerplate front skid plate, Kayline Soft Top , Clear Corners and Turn Signals, Eagle Alloy Rims with 31x10.5x15 M/T tires, 2 12" JBL Subwoofers / MTX AMP, Pioneer Premiere Speakers, JVC KD-G730 MP3/CD/Bluetooth |
#4 (permalink) |
When you're towing, turn the O/D off. I like to use ECT pwr on my '93 when I'm driving on hilly roads. It minimizes the upshift / downshift problem with the 3.slow slightly.
__________________
2002 4Runner, Auto-A340F, 3.4L, 4.30 Gears TJM T15 Front Bumper & Warn M8000, 4xInnovation sliders, Sonoran Steel 1.2 Lift, Toytec LCA Skids, Tundra Brake Upgrade (231mm), Extended rear diff breather, Deckplate Mod, Andymod, Dual batt setup with Optima blue top aux battery, Hardwired 1000W inverter, Aux fuse box, Full time power to 12V plugs, Yaesu FT7800R Radio, "4-air" system for airing up/down tires. 2004 Camry LE - stock (and will stay that way) 1993 4Runner has been sold |
#5 (permalink) |
Leaving it on wont really help you get going, since it only allows the engine to rev higher prior to shifting and only at certain throttle positions. It has no effect at low revs.
Change your diff gear ratio for more torque (or get a diesel engine).
__________________
00 4Runner SR5 4x4 |
#6 (permalink) | |
i drive w/it on all the time
the only reason my mileage is affected is because i stay on the throttle longer
__________________
sarcasm noted...and appreciated im with the banned Quote:
| Tags |
| 1989, 4runner, 92, 98, auto, button, camry, driving, ect, ectpwr, pwr, sct, tacoma, toyota, turn, working |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| does the ECT button do anything? | ETRNL | Newbie Tech Section | 30 | 02-16-2008 10:19 AM |
| ect button | Jay1 | Newbie Tech Section | 14 | 12-29-2006 11:19 PM |
| ECT button | 881stGenRunner | 84-85 Trucks & 4Runners | 3 | 03-29-2006 05:43 PM |
| what does the ECT button do? | 994runnerguy | 95.5-2004 Tacomas & 96-2002 4Runners | 14 | 08-18-2004 07:17 PM |
| O/D off and ECT Pwr not working | saundelt | 95.5-2004 Tacomas & 96-2002 4Runners | 7 | 04-09-2004 11:08 PM |
