Sign in using an external account
| 95.5-2004 Tacomas & 96-2002 4Runners 4th gen pickups and 3rd gen 4Runners |
| Welcome to Yotatech! |
LinkBack | Thread Tools | Search this Thread |
#1 (permalink) | ||||
Personal
Sales Rating: (0)
ECT button manual trans
__________________
1989 4R 3VZ Manual 32X11.50 BFG AT Saggy Butt Last edited by thedanned; 04-04-2012 at 08:46 PM. Reason: added info |
#2 (permalink) |
Personal
Sales Rating: (0)
[OP]
Wait a minute I found my answer - I forgot about the ID Label on the LF door.
Ill take a look at it tomorrow and see what it says.
__________________
1989 4R 3VZ Manual 32X11.50 BFG AT Saggy Butt |
#3 (permalink) |
Personal
Sales Rating: (0)
u can also look at the bolts that hold the brackets and pedals in, does the lines that go to the slave look new? or ran my the manufacturer? if they did the 5 speed swap i dont see it being a bad thing, after all i did it to my rig.
#4 (permalink) |
Personal
Sales Rating: (0)
[OP]
Well I bought it. Door tag says R150F so I dont know whats up with the ECT button. Ill post up in the newbie section to reintroduce myself but for now heres a couple of pics. First things first: remove the running boards! God I am so glad to be back in a Yota.
__________________
#5 (permalink) |
Personal
Sales Rating: (0)
not too bad of a looking rig, it might change the fuel and timing a little or then needed something to fill a open spot and thats what they came up with and it might not even be hooked up.
#6 (permalink) |
Personal
Sales Rating: (0)
Dig into the dash to see if it is hooked up
__________________
2000 Tundra Ex-cab| 2UZ-FE| 130K miles| SR5 TRD|2" front spacers|285/75R16 GY Wrangler MT/Rs| 2.5" exhaust| Custom sliders| bobbed frame| custom flat bed| Dedicated off-roader in the works. '95 4runner|22re|5spd|157K miles| 2" BL| 33x12.5 m/t |anti-sway bars removed f/r| Warn manual hubs| PaceSetter header| 2.25" exhaust| Custom front bumper, 4xInno sliders|Rebuilt engine| Daily Driver '88 4runner|22re|5spd|206K miles|Sold '93 single cab|22re|5spd|150K miles|Sold |
#7 (permalink) |
Personal
Sales Rating: (0)
[OP]
Thanks! Theres been some body work but it came with eight years of maintenance receipts so I was happy with that. Its got the rear e-locker too which pretty much sold it for me.
The ECT button is backlit so the harness is hooked up. Ill dive in this weekend and see where it leads.
__________________
#8 (permalink) |
Personal
Sales Rating: (0)
5spd + E-locker? Damn. Thats nice
__________________
#9 (permalink) |
Personal
Sales Rating: (1)
could be the PO did the center bezel mod
__________________
Hilux Surf KZN185W SSR-G l 3.0L TDI l Dual Batteries l LT285/75R16 l Recaro Seats Drive Your Dreams |
#10 (permalink) |
Personal
Sales Rating: (0)
[OP]
Hmm from what I read here
http://m.yotatech.com/showthread.php?t=43660&page=2 That is to put a 99+ bezel in but mine is a 99. Am i missing something? That does look like my bezel. |
#11 (permalink) |
Personal
Sales Rating: (1)
Maybe your original bezel was broken somehow, so they swapped it out with another one?
__________________
97 4runner SR5 ARB bumper, M8000 winch, Custom rear bumper w/ tire carrier, 4.30's, E-Locker Retrofit, Tepui Kukenam Rooftop Tent, Hiflow exaust, ISR/deckplate mod, Trail Gear sliders, Hayden tranny cooler, JDM Field Monitor Unit, Bilstein 5125's, OME 861 Coils, Toytec Coilovers, Camburg UCA's, 1" Toytec BL, 305 X 70 BFG KM2's on rock crawler wheels perssonmotorsports.com/ |
#12 (permalink) |
FormerVendor
Personal
Sales Rating: (0)
Does your cruise control work?
#13 (permalink) |
Personal
Sales Rating: (0)
[OP]
Nope. Cruise light comes on but it wont set.
__________________
#14 (permalink) |
FormerVendor
Personal
Sales Rating: (0)
I'd do a voltage check on the ECT terminal coming out of your cruise control ECU. ALLDATAdiy says that it should be between 8-14v.
#15 (permalink) |
Personal
Sales Rating: (0)
[OP]
Ok. What are you driving at?
__________________
#16 (permalink) |
Personal
Sales Rating: (0)
I thought ECT was only active for automatics ???
__________________
99 SR5 V6 Auto 4WD, deck plate, TRD exhaust,Sonoron steel 7.2, Waag Nerfs, Wet Okole's, Load warrior, Optima red top// 86 Turbo SR5 4Runner, TEC T3 turbo,2.5 " exhaust, ARB suspension, Rustoleum paint (Money pit) |
#17 (permalink) |
Personal
Sales Rating: (0)
X2 On This
__________________
99 Hilux Surf Limited 4WD
#18 (permalink) |
Personal
Sales Rating: (0)
Or someone wanted another switch for something.
My wife's '96 has a few 4Runner switches in it that aren't original equipment. Running lights, auto-antenna turn off (for playing CD's), stuff like that. Random switches from the pick-n-pull look better and fir properly. Oh and *high-five* to the OP for the 5-spd e-locker. I had to look for a long while to find mine. '99 Highlander 5-spd e-locker. Yours looks like a Higlander package too, SR5 with body colored bumpers and a snort-hood. Good stuff. Mine's green and has the no-running board flares. Last edited by Jomoka; 04-06-2012 at 12:06 PM. |
#19 (permalink) |
Personal
Sales Rating: (0)
[OP]
Thanks for all the insight everyone. I installed my stereo today and found that the button is definitely plugged in. The po must have changed the bezel or clock at some point. When I was putting it back together I plugged the harness into the back of the ETC button and noticed the clock and rear defrost werent working. I removed the harness from there and plugged it into the back of the clock and they came back.
Took the running boards off too.
__________________
#20 (permalink) | |
Personal
Sales Rating: (0)
[OP]
Quote:
What do you mean by this?
__________________
| Tags |
| 2002, 4runner, auto, button, buttonmanual, ect, manual, mod, standard, tacoma, toyota, transmission, truck, work, yotatech |
