| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
E-Locker Retrofit TOTAL cost & wiring?
__________________
99 Highlander Jardine Cat Back Exhaust TRD Tundra/OME Suspension Pro Comp Xtreme MTs 285/75/16 Pro Comp 7089s 16x8 Stubbs Sliders |
#2 (permalink) |
if you dont mind, im going to add a second question to your post - Who Is the guy who retro-fits non locker 3rds into locked 3rds? I think he's in arizona??
__________________
2000 4Runner v6 sr5 4x4 5spd: Turbo'ed 99 4Runner v6 Sr5 4x4 5spd: Saw's / OME combo TrueTrac rear 98 4Runner V6 Sr5 4x4 5spd E-locker: Saws / OME combo... EEZI AWN Roof Tent 1.4m 97 4Runner V6 Sr5 4x4 Auto: Saws / OME combo TrueTrac rear 2003 Landcruiser 285 BFG At's and outback roofrack My Baja Trailer Build: http://forum.ih8mud.com/showthread.php?t=179520 http://community.webshots.com/user/bajaroadtrain |
#3 (permalink) |
I did mine for $550 and got most of the wiring I needed for free when I bought the e-locker 3rd. I would go for the whole axle (as long as its not bent).
__________________
Rob 1999 4Runner Limited 4x4, retrofitted e-locker/ ARB front locker with 4.88 Precision Gears, Tundra/LC lift, 2" 4Crawler BL, Nitto Mud Grappler 35's on 16x8, Marlin sliders, TJM T-15, Warn M8000 w/ synthetic line, Mad Mike's custom rear Bumper, deckplate and ISR mods, Vortex Muffler, custom made tube doors pictures here I support Banned Neliconcept |
#4 (permalink) |
Don't mind at all, that is what this site is all about anyway.
__________________
#5 (permalink) |
where r u guys finding parts? must have an E locker myself. i think This is a write up about retrofitting a non-locker 3rd.
__________________
My Profile |
#6 (permalink) |
oops. i lied^ "bolted on locker 3rd." sorry for the tease
__________________
My Profile |
#7 (permalink) |
mine came with the truck so it cost me about 8500
#8 (permalink) |
Staff
Total cost really depends on where you source the parts and how much you're willing to spend. It can vary all over the place.
To eliminate the hassle of retrofitting a 3rd member, I bought a complete (drum to drum) '99 axle w/e-locker for $550 and I'm planning to get an ORS wiring harness for $160-$180. Total spent will be around $780. Still much cheaper to the comparable/alternative ARB locker. criagslist.com is good place to find one, must be patient though, search daily, call and email questions. Most sellers who part out 3rd gens have no idea what an e-locker is. I was fortunate to find mine here through a local member. |
#9 (permalink) |
Staff
Something else to consider...
Depending on how you perceive it, the only downside or upside is the added expense of re-gearing. i.e. My 4runner currently has 4.10's (5spd) but the axle I bought has 4.30's (auto) and I have 285's ready to mount. I would much rather prefer 4.30s but unfortunately, only Toyota makes them. That leaves me searching for a used front 3rd or spend a crap load of money to re-gear both f/r for a ratio that isn't ideal. |
#10 (permalink) |
SO, with the full axle replacement, is it pretty much plug and play with the ORS harness? I guess I'm wondering if you have to run a bunch of wires and such?
__________________
#11 (permalink) |
A 99 Highlander has IRS, Independent Rear Suspention. Your going to have to completely re-do the rear suspention of the Highlander to put a solid axle with a locker under it.
Looking at you avatar, looks like a 4runner. If you swap the entire housing, you can either run the a stock wiring harness for the diff and have it work as it would if it came stock. MY suggestion would be to make your own harness so that you can lock it whenever you wanted. (not only in 4L) |
#12 (permalink) | |
Quote:
IRS..... You may be thinking of something different.
#13 (permalink) |
__________________
GO DJ; Im the resident forum smartass, Get over it and use the search button Thumper 99 Taco 2.7 LockRight in the a$$ Armor: 4Xinnovation Sliders, Full BudBuilts on the Way. FR Susp: OME 881's + N91S RR Susp: Allpro 3" Springs, U bolt flip kit, Bilstein 5150's Sittin Sideways on 33X10.5 BFG MT Km1's Pics Or It Didnt Happen Crew Scuble Pacific Crawlers UltimateYota TTORA |
#14 (permalink) | |
Quote:
__________________
01 Tacoma DC TRD OR 4x4 |
#15 (permalink) |
I was looking at getting a complete e-locker axle for me '84 runner, and was wondering if any of the complete factory e-locker axles will bolt right up. Or would I have to have the spring perches cut and re-welded.
Just curious at this point as I had an offer on my runner (wasn't planning on selling) so no more mods for now. If this guy changes his mind though I'll be looking to do this mod.
__________________
84 4runner SR5, 5" suspension lift, 35" BFG's, 5spd 03 Tacoma Dbl Cab SR5, TRD Off-Road Package w/ E-Locker, Revo's |
#16 (permalink) |
I have a rear axle with e-locker located and the guy said that they have the entire truck there and I was welcome to take the harness and RR Diff switch also. Is that all that I need and will that just plug in and work?
__________________
#17 (permalink) |
When I swapped axles in my 96 4runner I got the wiring harness from the locker to the body and then used an inchworm control harness for the rest (still needed some addtional wire though) and the factory switch.
Swapping the whole axle is alot easier than modify the axle housing to accept the diff.
__________________
2000 Toyota 4runner auto, 4x4, elocker, budbuilt skid, Sonoran Steel 7.2, 265/75/16 Yokohoma Geolanders AT-S Just call me "T" |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| e-Locker retrofit on 3rd Gen | Ritzy4Runner | 95.5-2004 Tacomas & 96-2002 4Runners | 31 | 12-09-2008 08:49 PM |
| E-locker Retrofit | Albuquerque Jim | The Fab Shop | 7 | 02-24-2006 09:33 AM |
| E-Locker Retrofit | xstickfightx | Offroad Tech | 1 | 10-28-2005 09:18 AM |
| e-locker retrofit write up not working? | chuckd | 95.5-2004 Tacomas & 96-2002 4Runners | 2 | 07-18-2004 11:04 AM |
| retrofit locker | wtmtnterror | 95.5-2004 Tacomas & 96-2002 4Runners | 1 | 04-07-2004 06:37 PM |
