e-locker mod/pic request
Does anyone have a picture of what wire I need to actually ground? I have everything set up and ready to go, just don't know which wire to ground. I know that I need to cut the blue/red wire and I know that I need to ground the side coming out of the harness....just don't know which harness. The HBOSS write-up that everyone seems to have used is no longer there so I just need to know which harness to cut the wire from and I'll be good. Thanks@
If you're talking about the mod to use the locker in 2wd then you need to cut the wire and ground the end that comes from the 4wd ecu, the small black box in the driver side kick panel. The end of the wire that goes into the wiring harness can just be taped up.
After a ton of searching las night, I was able to find the pin-out of the harness and a tiny picture to verify the correct harness. I got it done and it works except I noticed that my locker seems to engage much slower now then it used to. Is this typical of this mod, or is it because I was engaging the locker while driving on the street (under 5mph of course.)? I would have to idle forward very slow for about 20-30 feet before the RR DIFF LOCK light would go solid and I would hear it lock...
My 08 e-locker is stock. I haven't done the mod yet....will be doing it soon though. It locks in sometimes immmediately and sometimes it takes a long frigg'n time.
By the way, locker in 2wd is BAD ASS!!!!!
justdifferentials
Just Differentials
06-13-2022 07:40 PM
1uzRunner
63
11-10-2018 03:58 PM
FS[GreatLakes]: $180 BJ Spacers, 1.5 Rear Lift, Rancho RS5000 Shocks
jaretstuff
10-22-2015 05:25 PM
zz_denis
09-06-2015 03:43 PM
