e-locker light on BUT NOT LOCKER OR SWITCH
GREAT! another electronic gremlin, done a few google searches and GREAT nothing, my e locker light comes on when the switch is not engaged and so does the abs light but the locker is not engaged. Then if i acrually hit the switch and engage is the light comes on strong and then turn it off the light shuts off but then slowly fades on and then after a few minutes the ABS light comes on again. WTF!!!!!!!!!!!!!!!!!!!!!!! HELP!:ma d2:
I've never seen this, or heard of it happening.
Time to break out a wiring diagram. It could be a bad ecu (behind driver's side kick panel), bad wiring (a short somewhere), or a bad limit switch on the locker itself. basically, something is making the car think the locker is engaged (limit switch engaged) when it isn't, which is (likely) causing the ABS to disable as normal.
06-01-2021 01:51 PM
jerusry
10-19-2015 05:28 PM
Johntom240
7
07-13-2015 12:18 AM
WTB[PacSoWest]: Looking for a electric locking differential motor/ actuator
AaronM
07-08-2015 07:15 PM
