E Aho Laula = Wider is better 2nd gen on stock 15x 10
Old 11-12-2003, 11:51 PM
bigKahuna's Avatar
Hey guys
E Aho Laula = Wider is better. They said it cant be done. A 15x 10 rims on a stock 2nd gen 1990 4runner without lifting and no rubbing. well I beg to differ....
Im Just bought a set of 15 x 10 Xtreme Alloys 1869, at 4wheelXXXXX sorry no free plugs here, for $212 for all 4 rims and removed my 31 x 10.5 tires from the old factory stock rim. Yes they are bubbled out like JLo's butt, but lets just say their Phat!!! I even tried them aired down to 18PSI no problems. I got that mini monster truck look with a full wheel well. No rubbing however its a tight fit as the wheel sticks out almost 2.3 inches. The true test will be at Pismo Beach on Saturday 11-29
Next step is probably a Daystar 2.25 rear space and a Swayaway 25/27mm tortion bar and twist here and there. Then some 31x11.5 or 31x12.5 tires. The current set up looks really tight though, as it is 3 inches wider than the stock rim. I'm pretty sure a 32x11.5 would rub with the 15x10 rim. I have heard that 32x11.5 is ok with 15x7 rims but nothing bigger. Also I ran into a guy who said he had a 35inch tire on a stock 4runner with the fenders chopped and pounded to death however he's a hardcore 4x4'er and pretty psycho and I wouldnt recommend it...
I'm a surfer and need a serious beach cruiser therefore E Aho Laula (wider is better) after all a Hummer H1 is low and wide.... The runner now feels like its a stabler platform with limited swaying. Ill try to post some pic soon. If anyone has any tips on the 31x12.5's please feel free to voice yourself
thanks Big Kahuna:pat:
Old 11-13-2003, 09:42 AM
Memphis4X4's Avatar
Sounds like it looks good and functions well for you. I would like to see the Pics.
MaHalo!!
David
Old 11-13-2003, 10:22 AM
Krash's Avatar
Before I lifted my truck I put my classic IIs 15x10s on with 32x11.50's and they only rubbed at full turn. Which could have been solved if I would have just pounded a couple things here and there. But didn't since I put on a 3" body lift.
Old 11-13-2003, 10:36 AM
SLC Punk's Avatar
Old 11-14-2003, 03:20 PM
Gabe's Avatar
series 1869...
Big Kahuna--how did you get that deal of $212 for all 4 rims??
Old 11-14-2003, 04:43 PM
bigKahuna's Avatar
reply to the rim deal
Got the rims as a second
someone had bought them and had a check fit however it didnt fit on that truck so I was able to buy them used however they were not even nicked what a bargain heh? well I just wheeled them and the are awsome in the mud...
check out the picts.....
Old 11-14-2003, 07:26 PM
Gabe's Avatar
lucky you... I never seem to get breaks like that! If you come across something similar drop me a line...
Old 11-14-2003, 08:17 PM
Plays_with_Toys's Avatar
Just curious since earlier this year there was a post with some hawaiian runners. Is the trend there to have those really wide tires because of the beach? Do alot of people take their trucks out there and they need the wide track in order to float over the sand?
Old 11-17-2003, 11:44 PM
bigKahuna's Avatar
Hawaiian Style
Hey guys
just for clarification in my picture I was giving the "hang ten" sign and definitly not the "you cut me off middle finger sign" also as to the wide tracks it is good on sand as it gives you a lower center of gravity and disperses your weight over larger distances(much like a Hummer H1). I noticed less body roll and better handling on the road it grips in the corners. However like all thing there are draw backs 1. is fitting in those darn small parking spots and tight trails. 2. is the mud kicks up really high and goes thunk when it hits your roof and hood. but did I mention how well it handles I mean I dont know why everyone doesnt go wide..... well gotta get some ZZZZZZZzzzzzzsss
Peace Big Kahuna
Old 11-18-2003, 12:24 AM
bigKahuna's Avatar
Need Help
Is Wider better than Higher or viceversa?? Please give your input.....
thanks Big K
06-01-2021 01:51 PM
Team420
12-30-2015 01:31 PM
exporunner
3.4 Swaps
08-03-2015 06:10 PM
vanion2
07-29-2015 06:17 PM
Steezy96yota
07-06-2015 10:00 AM
Quick Reply: E Aho Laula = Wider is better 2nd gen on stock 15x 10
