dual batteries? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 02-08-2003, 02:26 PM   #1 (permalink)
doink's Avatar
Send a message via AIM to doink
dual batteries?
anyone here have a dual battery set up? im thinkin of getting another battery to help spread the load my lights and other aux items that i may get. any advice?
doink is offline
Old 02-08-2003, 11:58 PM   #2 (permalink)
Sludge's Avatar
Send a message via AIM to Sludge
sorry i dont hve and answer but where would you put the extra batt
__________________
92 4Runner SR5
Aisin hubs,pin stripe removed,police scanner,brush guard,Monroe Senseatrak shocks and steering stablizer,Brembo rotors,Downey HD coils,Blue reverse indiglo guages. . .
http://community.webshots.com/user/sludg3
Sludge is offline
Old 02-09-2003, 12:09 AM   #3 (permalink)
Skydigger's Avatar
Quote:
Good question. I was inspired by 4crawlers set-up since I have the rear tire carrier I was thinking eventually a second battery could go under there.
__________________
1986 4Runner. SAS w/ chevies, 44044s, Roncho shocks, 35" MT/Rs and a spray bomb paint job! The wife drives the '90 4Runner now.
Skydigger is offline
Old 02-09-2003, 05:11 AM   #4 (permalink)
Cebby's Avatar
Send a message via AIM to Cebby
Optima
Gotta go Optima. You can mount them in any orientation (laying on their side for example, plus you don't have th off-gassing problems of regular batteries. I am planning to add one in the future, probably mounted somewhere out of harms way under the 4R. The only other question is how will you wire it up? Will you use an isolator, or wire in parallel (through a large relay). I have both of these and will shoot pics if anyone is interested.
__________________
UZswap.com
A site dedicated to sharing info for swapping the Toyota/
Lexus UZ (V8) engines into Toyota Trucks and 4Runners.
My 4Runner
1993 4Runner, 1UZ (V8) auto dual ultimate crawler, double locked, 35's on beadlocked SR5 alloys,
low lift, hacked fenders, tubbed firewall, custom armor
TOOLandFAB.com
A discussion forum dedicated to tools, fabrication & workshops. See my JD2 Bender Hydro Conversion
Cebby is offline
Old 02-09-2003, 08:49 AM   #5 (permalink)
hilandfrog's Avatar
2nd batt.
i put a yellow top as my second batt. I'm using it for lights, a heater in my shell and some power inverters. I went with a constant duty solinoid (SP) from an RV shop($28), a 30amp switch inside the cab($4) at radia shack, 20 of 4ga wire from home depo ($14) I covered the wire w/ new split fuel line and installed the whole thing. the second batt only charges if I want and will not drain the other batt unless i leave the switch on.
next I will add a relay so the switch will only have power if the key is in (not on) One more step to protect me from myself .
__________________
01' tundra.... "must have a little green man under the hood that controls things"
?? 4.7 liter ??
15mpg adv
plush ?truck?
"Keep both eyes open, keep the front sight focused and use good trigger control"
hilandfrog is offline
Old 02-09-2003, 09:58 AM   #6 (permalink)
kerrs's Avatar
I have two batteries, they are connected in parallel for extra cranking amps. But Bundubasher, has fitted one optima battery and changed his setup to a split charge.
You can just see the two batteries.
Kerr
__________________
<:::MY SITE:::>
'95 UK spec 4Runnner
3.0 Turbo Diesel
Safari Snorkel
Tinted Windows
Tinted Light Lenses
55W Reversing Lights
130W KC Dayliters
Aluminium Mats
Inclinometer
OME Springs & Shocks
kerrs is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
dual batteries w/out isolator dfoxengr Offroad Tech 5 02-26-2007 09:47 AM
Dual batteries under the hood BajaTaco General Vehicle Related Topics (Non Year Related) 85 03-01-2006 05:23 AM
Dual Batteries Installation Gangus2006 Vehicle Audio & Home Entertainment 29 06-03-2005 06:31 PM
dual batteries rugerm44 95.5-2004 Tacomas & 96-2002 4Runners 8 11-10-2003 04:58 AM
Dual Batteries Churnd 95.5-2004 Tacomas & 96-2002 4Runners 3 10-02-2003 05:01 AM
2009 InternetBrands, Inc.
