Dual Batteries - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 10-01-2003, 10:26 PM   #1 (permalink)
Churnd's Avatar
Send a message via AIM to Churnd
Dual Batteries
Ok, I know dual batteries have been discussed here a thousand times. I've been searching all night but not really finding what I need. I'm planning on running another battery along with my Everstart Maxx from WalMart. The extra battery is probably going to be an Optima Marine.
I have a pretty good idea of how I'm going to wire it up also. I'll probably order an isolator kit or make up my own. Basically, the kit will allow me to run the batteries at the same time, seperately, or to let the secondary boost the primary in the event that the primary ever dies. This is all provided I can find a place to mount the extra battery and keep it out of the way.
Now what's really stumping me is what I'm going to do about the alternator. The way I'm going to run the isolator is off of the main battery, instead of off the alternator, then to the secondary. I'm worried that my alternator isn't going to be up to the task of charging both batteries. I do have the 140 amp alt from Mr. Alternator, but I haven't successfully found a way to upgrade the charging wires from the alt. I ran a 8 guage wire parallel from the charging post to the battery with no luck. WATRD, however, successfully did this on his rig... a Tacoma.
So, what I need to know is, will my alternator be up to the task of charging 2 batteries or do I need to figure out how to upgrade the wires first? If not, I probably still will later... but I'd like to start running the dual batteries now.
Edit: Here's a site that I've been looking at for the isolator kit: Wrangler NW
__________________
-Chris
If you can't explain it simply, you don't understand it well enough.
Click here to search!
My Website
Churnd is offline
Old 10-02-2003, 01:08 AM   #2 (permalink)
ByThaBay's Avatar
Send a message via AIM to ByThaBay
my biggest concern with using the stock alternator wires would be that they would be too thin. you need a lower guage (thicker wire) if you plan on having the alternator change more.
just my $.02
ByThaBay is offline
Old 10-02-2003, 04:13 AM   #3 (permalink)
Super Moderator-Sponsoring Member
Staff
waskillywabbit's Avatar
Send a message via AIM to waskillywabbit Send a message via MSN to waskillywabbit Send a message via Yahoo to waskillywabbit
Best Thread I Read
This is the best thread that I have read so don't grab both poles on the battery or you might wind up dead! It's way too early in the morning to have to be awake!
If Baja Taco doesn't chime in, I'd PM him and check out his recent thread on a SWEET dual battery setup.
http://www.yotatech.com/showthread.p...dual+batteries
Brian
waskillywabbit is offline
Old 10-02-2003, 05:01 AM   #4 (permalink)
Churnd's Avatar
Re: Best Thread I Read
Brian
Yeah, it is pretty early, huh?
I read BajaTaco's post several times and it does provide a LOT of information, but it's also for a 3rd gen truck. I have a second gen truck. I guess the only difference would be that I need to figure out how my alternator is wired differently than his.
__________________
-Chris
My Website
Churnd is offline
Tags
09, 2003, 35s, alternator, audio, batteries, battery, charge, dual, everstart, kit, maxx, running, tacoma, toyota, walmart
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
dual batteries w/out isolator dfoxengr Offroad Tech 5 02-26-2007 09:47 AM
Dual batteries under the hood BajaTaco General Vehicle Related Topics (Non Year Related) 85 03-01-2006 05:23 AM
Dual Batteries Installation Gangus2006 Vehicle Audio & Home Entertainment 29 06-03-2005 06:31 PM
dual batteries rugerm44 95.5-2004 Tacomas & 96-2002 4Runners 8 11-10-2003 04:58 AM
dual batteries? doink 95.5-2004 Tacomas & 96-2002 4Runners 5 02-09-2003 09:58 AM
2009 InternetBrands, Inc.
