DRL help....
Old 09-10-2003, 07:18 PM
Mad Chemist's Avatar
DRL help....
Okay, so I went to do the DRL mod, actually want to wire it up to a toyota switch so that I can still run them on-road and such. I realized that I don't seem to have a relay box as pictured in the write-up that Ducky has, possibly due to the fact that I have an older third gen (1998). Does that mean that the DRL wire is coming out of the ECU box instead? Maybe I'm not looking in the right place, but if someone else with a 98 or older could chime in I'd appreciate it.
Old 09-11-2003, 08:33 AM
Anybody????? Is there anybody out there? (Pink Floyd playing in background...)
Old 09-11-2003, 09:28 AM
rixham's Avatar
Hmmmm...I wonder if it is the same on my 2000. I will have to check.
Old 09-11-2003, 09:52 AM
nrgetic99's Avatar
My 99 had no provision for DRL's....
Is yours even pre-wired for them ??
David
Old 09-11-2003, 10:34 AM
Ducky's Avatar
See this is getting odd... I think someone with a 2001 also said he couldnt find the box... i was thinking it would be easy... is mine the oddball? anyone else with a 3rd gen able to find the relay as per my instructions? maybe the box is somewhere higher in the dash?
Old 09-11-2003, 10:54 AM
hillbilly's Avatar
The DRL relay for the '01s is there, its just in a different location. In the '01, the DRL relay sits behind the kick plate under the steering wheel, not in the engine compartment.
Old 09-11-2003, 11:01 AM
Ducky's Avatar
ahh ok, so my instructions should say "how to disable your DRL's on a 2001 4runner"?
Old 09-11-2003, 12:42 PM
So do you have to drop the panel beneath the steering wheel to see it? I was under the impression that is was visible by just crawling underneath to take a look.
Old 09-11-2003, 12:44 PM
Ducky's Avatar
unless mine is missing something, all I had to do was look under the dash towards the right hand side.
Old 09-11-2003, 01:48 PM
Hmmm, I'm definitely not seeing anything remotely the same on mine. I have a 98 from Canada, which maybe was setup a little differently?
Old 10-10-2005, 09:05 AM
yozhik83's Avatar
I have a 3rd Gen. and did the mod....my DRL box is right under the dash by my right shin, just next to the steering column. Just where I thought everybodies was. Easy to see, didn't have to remove anything to see it. But has anyone noticed that after the mod is done, the lights don't turn off when you open the drivers door upon exiting the vehicle as they used to? I'm a little mad about this problem....any help?
Old 10-10-2005, 09:53 AM
ebelen1's Avatar
What is the DRL mod. Sorry for the newb question.
Old 10-10-2005, 01:14 PM
BennyTRD's Avatar
I had a hard time finding the box on my '97 at first, but I got it all figured out. Here's a link to the original thread. This method is much easier than cutting wires.
https://www.yotatech.com/forums/show...&highlight=DRL
91 4Runner
10-21-2007 11:39 AM
Corey
08-10-2006 01:59 PM
Corey
06-08-2006 02:18 AM
okkin
07-19-2005 08:59 PM
Quick Reply: DRL help....
