driving lights not working
my front driving lights work and my brake lights work but my rear driving lights dont work?
is there a fuse somewhere or some easy fix
Originally Posted by patterson
checked all my fuses and found the left hand headlight blown i replaced it and i still dont have dash or driving
In addition to tysons suggestion. I would re-check the fuse to the left headlight again. You might have a short somewhere in the system that is blowing the fuses as fas as you are putting them in.
Like the guys said check the fuses in the cab, especially the fuse box behind the kick panel on the drivers side
Bigger second pic
Bigger second pic
I guess its time to bust out the voltimeter and start checking to see if your even getting power. Where or how your suppose to accoplish this you ask? Im hopping one of our electrical experts will drop in. soyy I cant help more
also my dash lights dont work either
wonder if they work together
You go through deep water lately? Done any work on your truck?
i have went through alot of deep water but im not even sure when they stopped working or if they have since i got the truck first time ive driven it in the dark
i found the problem while checking under dash fuses i saw there was something missing and it looked likea plug in and in letters above it said wow tail light relay, checked my paretsn toyota and there it was so i got one put it in and its works great
thanks for all the help guys nice to have a second opinion
LSUMatt1514
06-26-2002 05:03 AM
