Driveshaft Question?
Old 03-19-2010, 04:16 AM
traxxi2003's Avatar
I have a 1997 4Runner SR5 2WD. Can anybody tell me, If this trucks driveshaft are considered a sigle peace or a double peace driveshaft? By looking at it looks like a single peace but towards the rear protion of the drive shaft it looks like the rear portion of the drive shaft slides into the front portion of the driveshaft. It also has a rubber "oring like" covering the section where the two peaces unit. I try to pull them apart, but they won't move. The reason i'm asking is because I recently lifted my truck and now I'm having some driveline vibrations. I was told that I need it to legnthen the drive shat to compensate for the lift. Any help will be greatly appreciated. thanks!
Old 03-19-2010, 04:32 AM
Fossilized
Staff
dropzone's Avatar
you have a one piece drive shaft. a two piece shaft would have a carrier bearing mounted midway from the transmission to the rear of the truck.
the rubber ring you are seeing acts like a seal to protect the slip joint splines
edit: maybe more than you want to know but here are some good links on driveshafts
4crawlers: http://www.4crawler.com/4x4/CheapTri...line-101.shtml
driveshaft401: http://www.pirate4x4.com/tech/billav...aft/index.html
this link has some great pics about midway down showing the rubber ring/slip joint i did a bad job of explaining
http://www.pirate4x4.com/tech/billavista/Driveshafts/
Old 03-19-2010, 05:41 AM
traxxi2003's Avatar
Ok! One piece driveshaft. Now, the slip joint splines U mentioned above, assuming U aren't refering to the one that goes into the trany, they are designed to slip in and out as required to compensate for any changes on the suspenssion (ie, lift install). Correct?
Old 03-19-2010, 05:59 AM
mt_goat's Avatar
Well... to compensate for changes in suspension as you drive and hit bumps and stuff, and that's why you shouldn't over-fill the slip joint with grease.
Old 03-19-2010, 06:54 AM
hross14's Avatar
AND--if you seperate the two pieces for whatever reason--make sure you clock them by marking both pieces (I.e.--has to go back together exactly the way it came apart).
If not you will get driveline vibrations
4x4-runner
04-18-2017 09:08 PM
mussy01
12-13-2016 08:20 PM
Tonetrk
08-06-2015 10:06 AM
gillesdetrail
08-03-2015 04:43 PM
Sr5crawler
07-31-2015 12:32 PM
Quick Reply: Driveshaft Question?
