driveshaft leak
Old 05-18-2004, 09:49 AM
Y2Krunner's Avatar
driveshaft leak
i just drained and filled the transfer case on my 00 4runner. Capacity is 1.2 quarts i beleive and a fraction of that came out. so i topped it off and took it for a drive. now i have oil pumping out of the seal where the drive shaft connects to the transfer case. Questions: what seal is that? will it pump out ALL of the fluid i just put in? and would it be covered in the drivetrain portion of the warranty?
Old 05-18-2004, 12:27 PM
aowRS's Avatar
Was the truck sitting on a hill with the nose pointing down? That would allow you to possibly add too much. When I did mine at about 40,000 miles, I filled it until it started dribbling out and called it done. Its been fine and I'm at 73,000 now. Could you be confusing the 75W oil with the sticky srayed-on stuff that is all over my transfer case?
Andreas
Old 05-18-2004, 02:18 PM
Y2Krunner's Avatar
i had the truck pretty even- ramps under all 4's on a level surface. It puked out quite a bit initially after the first drive, and it was infact coming from that seal as mentioned earlier.
94yotaky
08-19-2015 11:15 PM
trailgoat
08-13-2015 05:54 PM
Tonetrk
08-06-2015 10:06 AM
Sr5crawler
07-31-2015 12:32 PM
Avenged
07-09-2015 07:55 AM
Quick Reply: driveshaft leak
