driveshaft interchangeable part from 4runner to a tacoma?????????
Old 09-01-2014, 12:14 PM
tocarunner's Avatar
hi,
i recently broke my rear driveshaft in my 1996 extended cab, 4x4, manual trans, 4 cylinder tacoma (2.7L).
my question is, can i grab a rear driveshaft from a 1996, 4x4, 4 cylinder, manual trans 4runner?
will it just bolt right in?
tacoma rear driveshaft is a two piece with a carrier bearing, and a slip yoke.
Old 09-01-2014, 01:16 PM
scuba's Avatar
No. The 4Runner driveshaft is a 1 piece and is around 20" shorter than a Tacoma 2 piece.
Old 09-01-2014, 08:05 PM
Staff
DeathCougar's Avatar
What he said. Good thing is, any X-cab Tacoma uses the same length rear half. The difference in the drivelines is in the front half, so if the front half of yours is OK you can swap the rear half and be good to go.
Old 09-01-2014, 09:41 PM
tocarunner's Avatar
Are you sure about this?
What about the bolt pattern on the diff, are they all the same? Ex: open diff or a electric locker?
Old 09-03-2014, 06:15 PM
Staff
Yep, 100% sure.
All the 95-04 Tacomas use the same flange on the diff, regardless of Open or E-locked.
AustinTaco
08-22-2022 10:45 AM
vasinvictor
01-20-2016 12:39 PM
PureTacoma_Tundra
PureTacoma_Tundra
06-29-2015 09:45 AM
Valvoman
06-28-2015 02:45 PM
TheManOutside
06-18-2015 03:32 PM
Quick Reply: driveshaft interchangeable part from 4runner to a tacoma?????????
