| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Driveshaft center bearing
__________________
'99 4Runner, 3.4 s/c, 5 spd. 3'' lift '03 Tacoma DoubleCab |
#2 (permalink) |
The play is normal. The bearing is contained by a rubber "shock absorber" boot. The bearing slides over the drive shaft and that rubber bumper allows the drive shaft to move around (absorbed by the boot). You will know when the carrier bearing goes bad because there will be a squeak in sync with your rpms.
__________________
'99 Tacoma 5spd 2.7 4WD Xtra cab TRD K&N Intake, headers, Hella's, Magnaflow cat, cat-back w/ Magnaflow exhaust, gray wire, fosgate(s), Kenwood deck. Hopefully more to come. '05 Banshee scream 5th element rear, setup for 7/7-->'06 custom welded steel DJ/trials frame. Line-X frame coat. Avid BB7 mech. My first frame job. holding strong |
#3 (permalink) |
ok thanks, no noises yet so I guess I'm good for now
__________________
#4 (permalink) |
Check your engine and tranny mounts.
__________________
~Dale~ 93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift front, Alcan springs rear, 33 BFG MT, ARB locked front & rear, 5.29 US Gears, RB 1" Body Lift, 1.5" ball joint spacers, manual hubs, TJM T-17, Warn m8000. |
| Tags |
| 2004, bearing, carrier, center, drive, driveshaft, pickup, replacing, shaft, tacoma, toyota |
