Driveshaft on 2WD
Driveshaft on 2WD
Hey,
Has anyone out there had any problems with a 94 4Runner driveshaft.
I have a rumbling coming from under the truck, and I initially though it to be the rear end. I replaced it with a 95 rear end with 32,000 miles, but the rumbling is still there. The shaft is within the .030 in round out, and when I run just the engine and trans, there is no rumbling. The rumbling starts at about 50mph and gets worse and the speeds increase.
Any Ideas?
Thanks
Any Ideas?
Thanks
Originally Posted by crazybout4runners
Hey,
Any Ideas?
Thanks
Any Ideas?
Thanks
does it have a one or two piece driveshaft? if its got a two piece, then that sounds like a center support bearing or also called a carrier bearing going bad
kawazx636
10-06-2021 03:03 PM
Dale Johnston
11
10-31-2015 10:22 PM
Cycles
09-29-2015 06:37 AM
